1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Long string support in CA clients and device support
Cc: Tech-talk <[email protected]>, Eric Norum <[email protected]>
Date: Thu, 15 Nov 2012 09:52:03 -0600
On 11/14/12 4:42 PM, Andrew Johnson wrote:
> Hi Mark & Eric,
> On 2012-11-13 Mark Rivers wrote:
>> Consider the following little database:
>> So now clients will face two different meanings of NORD.
> Yes, but I don't agree that it means there are two different meanings of NORD,
> which in all cases tells you how many elements are stored in the array.  A Nil
> byte is an integral part of a C string, so it should be included when copying
> a string.  Your ID waveform does not hold a C string however, it stores an
> array of characters, which you can convert into a proper string by appending a
> terminator.
> Look at the following C definitions:
>     char *str1   = "abcd";
>     char str2[5] = "abcd";
>     char str3[4] = "abcd";
>     char str4[]  = {'a', 'b', 'c', 'd'};
>     char str5[]  = "abcd";
> The C compiler automatically adds a terminator to string literals everywhere
> that it can, so only str3 and str4 will not have a Nil terminator immediately
> following the 'd' in memory.  It can't for str3 because the storage allocated
> for the array is too small, and str4 is explicitly initialized with chars so
> it's not a string, but sizeof(str5) = 5 not 4; the compiler allocates space
> for the terminator because the array was initialized as a string.
Hi, Andrew.
The problem with this logic is that you're thinking of a waveform
record's VAL field as a C string.  The fact that C strings and C char
arrays have some overlap and can sometimes be treated in the same way
should not affect how we think about the waveform record's VAL field.
The waveform record's VAL field is an array of items of some type.  It
is not a C string.  If you store a sequence of chars in a waveform
record's VAL field, including the NUL byte makes no sense to me since
that is a C string terminator, but the waveform record's VAL field is
not holding a C string; it's just holding a sequence of chars.
Another problem with including the NUL byte is that if I fetch a
waveform record's VAL field from another language, say Java, I now have
to do extra work by checking to see if the NUL byte is included and
throw it away if it is; it's a totally bogus character in this context.
Lewis
Re: Long string support in CA clients and device support Andrew Johnson
RE: Long string support in CA clients and device support Mark Rivers
Prev: Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
Next: Re: StreamDevice and sCalcoutRecord.h Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Long string support in CA clients and device support Andrew Johnson
Next: Re: Long string support in CA clients and device support Andrew Johnson
