1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DB Question
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 16 Nov 2012 09:01:19 -0800
Thanks Mark,
I guess that is what is going on.  I will look at this.
Zen
Sent: Friday, November 16, 2012 8:58 AM
To: Szalata, Zenon M.; [email protected]
Hi Zen,
Remember that standard asyn device support for output records does the following at iocInit:
1)      Attempts to read the current value from the asyn port driver
2)      If that read returns asynSuccess then the VAL field in the record is replaced by the one read from the driver
3)      If that return does not return asynSuccess then the VAL field is not modified
This behavior is designed to support “bumpless reboots”.
I suspect your driver is returning asynSuccess on a call to asynInt32->read() at iocInit.  If you want to preserve the value of the VAL field from the database file then your driver must not return asynSuccess.
From: [email protected] [mailto:[email protected]] On Behalf Of Szalata, Zenon M.
Sent: Friday, November 16, 2012 10:32 AM
To: [email protected]
Subject: DB Question
I am a bit confused by the following behavior.
I am using EPICS R3.14.12.2 and asyn R4.20.
I have a simple longout record:
record( longout, "$(P):$(N):LO:BTOI:NCOEF"){
  field( DESC, "N Coefs:")
  field( DTYP, "asynInt32")
  field( OUT,  "@asyn($(PORT),$(N),1)LO_NCOEF")
 field( VAL,  "2")
  field( PINI, "1")
After this record is done initializing, caget on it gives me 0.
I have introduced another record as follows:
record( longout, "$(P):$(N):LO:NCOEF"){
  field( VAL,  "2")
  field( OUT,  "$(P):$(N):LO:BTOI:NCOEF PP")
  field( PINI, "1")
# field( VAL,  "2")
#  field( PINI, "1")
With these two records the second one now has the correct value.
Why does the single record solution lose its VAL value?
Thanks in advance,
Zen
DB Question Szalata, Zenon M.
RE: DB Question Mark Rivers
Prev: RE: DB Question Mark Rivers
Next: RE: DB Question nick.rees
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
