Subject: RE: DB Question
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 16 Nov 2012 09:37:44 -0800
This is an interesting way to solve it.  I will test it.
Zen
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> Sent: Friday, November 16, 2012 9:23 AM
> To: [email protected]; Szalata, Zenon M.; [email protected]
> IIRC (I don't have the code in front of me at the moment) the way to override
> this asyn behavior is to set OMSL to Closed Loop and DOL to a constant value.
> Cheers,
> Nick Rees
> Principal Software Engineer           Phone: +44 (0)1235-778430
> Diamond Light Source                  Fax:   +44 (0)1235-446713
> Mark Rivers <[email protected]> wrote:
> Hi Zen,
> Remember that standard asyn device support for output records does the
> following at iocInit:
> 1)      Attempts to read the current value from the asyn port driver
> 2)      If that read returns asynSuccess then the VAL field in the record is
> replaced by the one read from the driver
> 3)      If that return does not return asynSuccess then the VAL field is not
> modified
> This behavior is designed to support "bumpless reboots".
> I suspect your driver is returning asynSuccess on a call to asynInt32->read() at
> iocInit.  If you want to preserve the value of the VAL field from the database file
> then your driver must not return asynSuccess.
> Mark
> On Behalf Of Szalata, Zenon M.
> Sent: Friday, November 16, 2012 10:32 AM
> Subject: DB Question
> Hi,
> I am a bit confused by the following behavior.
> I am using EPICS R3.14.12.2 and asyn R4.20.
> I have a simple longout record:
> record( longout, "$(P):$(N):LO:BTOI:NCOEF"){
>   field( DESC, "N Coefs:")
>   field( DTYP, "asynInt32")
>   field( OUT,  "@asyn($(PORT),$(N),1)LO_NCOEF")  field( VAL,  "2")
>   field( PINI, "1")
> After this record is done initializing, caget on it gives me 0.
> I have introduced another record as follows:
> record( longout, "$(P):$(N):LO:NCOEF"){
>   field( VAL,  "2")
>   field( OUT,  "$(P):$(N):LO:BTOI:NCOEF PP")
>   field( PINI, "1")
>   field( OUT,  "@asyn($(PORT),$(N),1)LO_NCOEF") # field( VAL,  "2") #  field(
> PINI, "1") }
> With these two records the second one now has the correct value.
> Why does the single record solution lose its VAL value?
> Thanks in advance,
> Zen
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only. If you
> are not the intended addressee or an authorised recipient of the addressee
> please notify us of receipt by returning the e-mail and do not use, copy, retain,
> distribute or disclose the information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and not
> necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any attachments
> are free from viruses and we cannot accept liability for any damage which you
> may sustain as a result of software viruses which may be transmitted in or with
> the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
DB Question Szalata, Zenon M.
RE: DB Question Mark Rivers
RE: DB Question nick.rees
Prev: RE: DB Question Szalata, Zenon M.
Next: EPICS on SL6.x Ibrahim Saleh
Prev: RE: DB Question nick.rees
Next: RE: DB Question Mark Rivers
