1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caRepeater object code not cross-compiled in R3.14.12.2
Date: Thu, 22 Nov 2012 09:39:13 +0100
Hello Rod,
In src/ca/Makefile, you find caRepeater in PROD_HOST. Thus it is not made for cross builds. Try to take it out and instead set
PROD_DEFAULT = caRepeater
PROD_vxWorks = -nil-
This should build the caRepeater for all non-vxWorks architectures, not only for the host architecture.
Dirk
On 21.11.2012 18:57, Rod Nussbaumer wrote:
Hi all.
Did I do something wrong?
My $EPICS_HOST_ARCH is linux-x86. I've added to
configure/os/CONFIG_SITE.linux-x86.Common the line:
CROSS_COMPILER_TARGET_ARCHS = linux-arm
In configure/os/CONFIG_SITE.linux-x86.linux-arm, I've set $GNU_DIR&
$GNU_TARGET to identify the name and location of my cross toolchain.
The build completes normally, and in bin/linux-arm I see a small number
of channel access tools, as well as a script to launch caRepeater, but
no caRepeater binaries. The tools built for the cross-compiled
architecture seem to work normally. My target architecture is a full-on
Linux host, which may run multiple IOC applications, and should be using
caRepeater.
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Prev: Re: 3.14 v.s. 3.15 vs. v4 Pete Jemian
Next: Get a time difference in EPICS database 洪春霞
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Next: Re: caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
