1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caRepeater object code not cross-compiled in R3.14.12.2
To: [email protected]
Date: Sun, 25 Nov 2012 09:14:20 -0800
Hi, Dirk.
Thanks, that did the trick. I replaced PROD_HOST with PROD_DEFAULT and
built everything that way.
For target architectures that are Linux, it feels as if this should be
the default. Without having explored this very deeply, I wonder whether
the properties of $EPIC_HOST_ARCH shouldn't be applied to all Linux
target architectures. Is anyone using Linux targets in a way that this
would not make sense?
   ---  rod.
On 11/22/2012 12:39 AM, Dirk Zimoch wrote:
> Hello Rod,
> In src/ca/Makefile, you find caRepeater in PROD_HOST. Thus it is not
> made for cross builds. Try to take it out and instead set
> PROD_DEFAULT = caRepeater
> PROD_vxWorks = -nil-
> This should build the caRepeater for all non-vxWorks architectures, not
> only for the host architecture.
> Dirk
> On 21.11.2012 18:57, Rod Nussbaumer wrote:
>> Hi all.
>> Did I do something wrong?
>> My $EPICS_HOST_ARCH is linux-x86. I've added to
>> configure/os/CONFIG_SITE.linux-x86.Common the line:
>> CROSS_COMPILER_TARGET_ARCHS = linux-arm
>> In configure/os/CONFIG_SITE.linux-x86.linux-arm, I've set $GNU_DIR&
>> $GNU_TARGET to identify the name and location of my cross toolchain.
>> The build completes normally, and in bin/linux-arm I see a small number
>> of channel access tools, as well as a script to launch caRepeater, but
>> no caRepeater binaries. The tools built for the cross-compiled
>> architecture seem to work normally. My target architecture is a full-on
>> Linux host, which may run multiple IOC applications, and should be using
>> caRepeater.
>> Thanks.
>> Rod Nussbaumer
>> ISAC Controls, TRIUMF
>> Vancouver, Canada
caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Re: caRepeater object code not cross-compiled in R3.14.12.2 Dirk Zimoch
Prev: Re: 答复: Get a time difference in EPICS database Tim Mooney
Next: 3.14 v.s. 3.15 vs. v4 Richard Farnsworth
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: caRepeater object code not cross-compiled in R3.14.12.2 Dirk Zimoch
Next: Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
