Subject: Re: caRepeater object code not cross-compiled in R3.14.12.2
To: Rod Nussbaumer <[email protected]>
Date: Tue, 27 Nov 2012 13:53:09 -0500
Hi there,
> On Wed, Nov 21, 2012 at 12:57 PM, Rod Nussbaumer <[email protected]> wrote:
> The build completes normally, and in bin/linux-arm I see a small number
> of channel access tools, as well as a script to launch caRepeater, but
> no caRepeater binaries. The tools built for the cross-compiled
> architecture seem to work normally. My target architecture is a full-on
> Linux host, which may run multiple IOC applications, and should be using
> caRepeater.
According to EPICS R3.14 Channel Access Reference Manual [1], I think
caRepeater is only needed when multiple CA clients (CSS, EDM, etc.)
run on the same host. Why should multiple IOC applications on the same
Linux host be using caRepeater?
Jack
[1] http://www.aps.anl.gov/epics/base/R3-14/12-docs/CAref.html
Re: caRepeater object code not cross-compiled in R3.14.12.2 Andrew Johnson
caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Prev: Re: Problem with medmfonts.ali running under Ubuntu 1204 Ivan Kohler
Next: Re: caRepeater object code not cross-compiled in R3.14.12.2 Andrew Johnson
Prev: Re: caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
