1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: caRepeater object code not cross-compiled in R3.14.12.2
To: [email protected]
Date: Tue, 27 Nov 2012 14:24:51 -0600
Hi Jack,
On 2012-11-27 Jack Smith wrote:
> According to EPICS R3.14 Channel Access Reference Manual [1], I think
> caRepeater is only needed when multiple CA clients (CSS, EDM, etc.)
> run on the same host. Why should multiple IOC applications on the same
> Linux host be using caRepeater?
An IOC is a CA client as well as being a server: record links often point to
records on other IOCs, the Access Security mechanism may subscribe to channels
on other servers, and any sequence programs running in the IOC also use CA.
The caRepeater is looked for and if necessary started at iocInit even if the
CA client library never actually has to make any external connections because
all of the PV names requested can be found locally within the IOC.
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Prev: Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
Next: Re: posix osiSpawnDetachedProcess inherits scheduling policy + priority Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
