Subject: Re: caRepeater object code not cross-compiled in R3.14.12.2
Cc: [email protected]
Date: Fri, 30 Nov 2012 10:51:55 -0500
Hi Andrew,
>On Tue, Nov 27, 2012 at 3:24 PM, Andrew Johnson <[email protected]> wrote:
> An IOC is a CA client as well as being a server: record links often point to
> records on other IOCs, the Access Security mechanism may subscribe to channels
> on other servers, and any sequence programs running in the IOC also use CA.
> The caRepeater is looked for and if necessary started at iocInit even if the
> CA client library never actually has to make any external connections because
> all of the PV names requested can be found locally within the IOC.
> - Andrew
Thanks for your detailed explanation.
I am trying to look through base-3.14.*/src/misc/iocInit.c. I guess
the only function related to caRepeater would be rsrv_init(). Then I
take a quick look at src/rsrv/caservertask.c, but still don't see how
the caRepeater get spawned. Could you tell me how the caRepeater is
started during iocInit? Also what does "rsrv" mean / stand for?
Thanks again,
Jack
Re: caRepeater object code not cross-compiled in R3.14.12.2 Ralph Lange
Re: caRepeater object code not cross-compiled in R3.14.12.2 Andrew Johnson
caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
Prev: Re: Several soft IOCs on one host Kasemir, Kay
Next: Re: caRepeater object code not cross-compiled in R3.14.12.2 Ralph Lange
Prev: Re: caRepeater object code not cross-compiled in R3.14.12.2 Andrew Johnson
