Subject: Re: caRepeater object code not cross-compiled in R3.14.12.2
To: Jack Smith <[email protected]>
Cc: [email protected]
Date: Fri, 30 Nov 2012 10:46:56 -0600
Hi Jack,
On 2012-11-30 Jack Smith wrote:
> I am trying to look through base-3.14.*/src/misc/iocInit.c. I guess
> the only function related to caRepeater would be rsrv_init(). Then I
> take a quick look at src/rsrv/caservertask.c, but still don't see how
> the caRepeater get spawned. Could you tell me how the caRepeater is
> started during iocInit? Also what does "rsrv" mean / stand for?
As Ralph said, the repeater is started by the CA client library, so the call
chain from iocInit() is that iocBuild() calls db/dbCa.c:dbCaLinkInit() which
starts dbCaTask() in its own thread, and that calls ca_context_create() to
initialize the CA client library and start the repeater if necessary.  Then
later on iocBuild() also calls as/asDbLib.c:asInit() which can also initialize
the CA client library via the code in as/asCa.c:asCaStart() although normally
the dbCaLinkInit() would have taken care of that.
I don't know what the "r" in rsrv stands for either; if he's reading this Jeff
Hill might remember...
HTH,
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
RE: caRepeater object code not cross-compiled in R3.14.12.2 Hu, Yong
caRepeater object code not cross-compiled in R3.14.12.2 Rod Nussbaumer
Re: caRepeater object code not cross-compiled in R3.14.12.2 Andrew Johnson
Re: caRepeater object code not cross-compiled in R3.14.12.2 Jack Smith
Prev: Re: caRepeater object code not cross-compiled in R3.14.12.2 Ralph Lange
Next: RE: CSS BOY left-mouse event Chen, Xihui
Next: RE: caRepeater object code not cross-compiled in R3.14.12.2 Hu, Yong
