Subject: Error building asyn4-20 on CentOS 6.3
To: [email protected]
Date: Mon, 26 Nov 2012 11:33:03 -0500
Greetings,
I have been trying to build the following asyn driver on my CentOS 6.3
(64bit) linux system but with no luck:
	http://www.aps.anl.gov/epics/download/modules/asyn4-20.tar.gz
First I found out a patch that needed to be applied to the code:
	http://www.aps.anl.gov/epics/tech-talk/2012/msg01794.php
Then the make went a bit further but then it ends with the following error:
<... snip ...>
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux
 -D_REENTRANT   -O3   -Wall      -m64      -I. -I../O.Common -I. -I.
-I.. -I../../../include/compiler/gcc -I../../../include/os/Linux
-I../../../include
-I/usr/local/epics/base-3.15.0.1/include/compiler/gcc
-I/usr/local/epics/base-3.15.0.1/include/os/Linux
-I/usr/local/epics/base-3.15.0.1/include       -MM -MF testMain.d
../testMain.cpp
Expanding dbd file ../testInclude.dbd
perl -CSD /usr/local/epics/base-3.15.0.1/bin/linux-x86_64/dbdExpand.pl
-I. -I.. -I../O.Common -I../../../dbd
-I/usr/local/epics/base-3.15.0.1/dbd -o test.dbd ../testInclude.dbd
Duplicate name 'asynRegister'
Context: file '../../../dbd/asyn.dbd' in file
'../../../dbd/drvAsynSerialPort.dbd' in file '../testInclude.dbd'
make[3]: Leaving directory
`/usr/local/epics/support/asyn/4-20/testApp/src/O.linux-x86_64'
make[3]: Entering directory
Installing dbd file ../../../dbd/devTestBlock.dbd
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/usr/local/epics/support/asyn/4-20/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/local/epics/support/asyn/4-20/testApp'
make: *** [testApp.install] Error 2
>From the output above, I'm not sure what the error is.
(I'm an EPICS newbie, so I'm probably missing something pretty obvious.)
I've attached the full make output.
Anyone else experienced a similar error before?
  Andre
André Charbonneau
make -C ./configure install
make[1]: Entering directory `/usr/local/epics/support/asyn/4-20/configure'
perl -CSD /usr/local/epics/base-3.15.0.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install
make[2]: Entering directory `/usr/local/epics/support/asyn/4-20/configure/O.linux-x86_64'
perl -CSD /usr/local/epics/base-3.15.0.1/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/usr/local/epics/support/asyn/4-20/configure/O.linux-x86_64'
make[1]: Leaving directory `/usr/local/epics/support/asyn/4-20/configure'
make -C ./makeSupport install
make[1]: Entering directory `/usr/local/epics/support/asyn/4-20/makeSupport'
mkdir O.Common
make[2]: Entering directory `/usr/local/epics/support/asyn/4-20/makeSupport/O.linux-x86_64'
Installing created executable ../../bin/linux-x86_64/makeSupport.pl
mkdir ../../bin
mkdir ../../bin/linux-x86_64
Installing ../../templates/top/Makefile
mkdir ../../templates
mkdir ../../templates/top
Installing ../../templates/top/configure/CONFIG
mkdir ../../templates/top/configure
Installing ../../templates/top/configure/CONFIG_APP
Installing ../../templates/top/configure/Makefile
Installing ../../templates/top/configure/RELEASE
Installing ../../templates/top/configure/RULES
Installing ../../templates/top/configure/RULES_DIRS
Installing ../../templates/top/configure/RULES_TOP
Installing ../../templates/devGpib/_NAME_Sup/Makefile
mkdir ../../templates/devGpib
mkdir ../../templates/devGpib/_NAME_Sup
Installing ../../templates/devGpib/_NAME_Sup/dev_NAME_.c
Installing ../../templates/devGpib/_NAME_Sup/dev_NAME_.db
Installing ../../templates/devGpib/_NAME_Sup/dev_NAME_.dbd
Installing ../../templates/devGpib/documentation/dev_NAME_.html
mkdir ../../templates/devGpib/documentation
Installing ../../templates/app/_NAME_App/Db/Makefile
mkdir ../../templates/app
mkdir ../../templates/app/_NAME_App
mkdir ../../templates/app/_NAME_App/Db
Installing ../../templates/app/_NAME_App/Db/_NAME_.db
Installing ../../templates/app/_NAME_App/src/Makefile
mkdir ../../templates/app/_NAME_App/src
Installing ../../templates/app/_NAME_App/src/_NAME_Main.cpp
Installing ../../templates/app/_NAME_App/src/sncExample.stt
Installing ../../templates/app/_NAME_App/Makefile
Installing ../../templates/vxioc/configure/RULES.ioc
mkdir ../../templates/vxioc
mkdir ../../templates/vxioc/configure
Installing ../../templates/vxioc/iocBoot/_IOCNAME_/Makefile
mkdir ../../templates/vxioc/iocBoot
mkdir ../../templates/vxioc/iocBoot/_IOCNAME_
Installing ../../templates/vxioc/iocBoot/_IOCNAME_/st.cmd
Installing ../../templates/vxioc/iocBoot/Makefile
Installing ../../templates/vxioc/iocBoot/nfsCommands
Installing ../../templates/vxioc.pl
Installing ../../templates/softioc/configure/RULES.ioc
mkdir ../../templates/softioc
mkdir ../../templates/softioc/configure
Installing ../../templates/softioc/iocBoot/_IOCNAME_/Makefile
mkdir ../../templates/softioc/iocBoot
mkdir ../../templates/softioc/iocBoot/_IOCNAME_
Installing ../../templates/softioc/iocBoot/_IOCNAME_/README
Installing ../../templates/softioc/iocBoot/_IOCNAME_/st.cmd
Installing ../../templates/softioc/iocBoot/Makefile
Installing ../../templates/softioc.pl
Installing ../../templates/streamSCPI/_NAME_Sup/Makefile
mkdir ../../templates/streamSCPI
mkdir ../../templates/streamSCPI/_NAME_Sup
Installing ../../templates/streamSCPI/_NAME_Sup/dev_NAME_.proto
Installing ../../templates/streamSCPI/_NAME_Sup/dev_NAME_.db
Installing ../../templates/streamSCPI/documentation/dev_NAME_.html
mkdir ../../templates/streamSCPI/documentation
make[2]: Leaving directory `/usr/local/epics/support/asyn/4-20/makeSupport/O.linux-x86_64'
make[1]: Leaving directory `/usr/local/epics/support/asyn/4-20/makeSupport'
make -C ./asyn install
make[1]: Entering directory `/usr/local/epics/support/asyn/4-20/asyn'
mkdir O.Common
make[2]: Entering directory `/usr/local/epics/support/asyn/4-20/asyn/O.linux-x86_64'
perl -CSD /usr/local/epics/base-3.15.0.1/bin/linux-x86_64/dbdToRecordtypeH.pl  -I. -I.. -I../O.Common -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../dbd -I/usr/local/epics/base-3.15.0.1/dbd -o asynRecord.h ../../asyn/asynRecord/asynRecord.dbd
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF boSRQonOff.d  ../../asyn/devGpib/boSRQonOff.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devSupportGpib.d  ../../asyn/devGpib/devSupportGpib.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devCommonGpib.d  ../../asyn/devGpib/devCommonGpib.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF TDS3000Reboot.d  ../../asyn/vxi11/TDS3000Reboot.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF E2050Reboot.d  ../../asyn/vxi11/E2050Reboot.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF E5810Reboot.d  ../../asyn/vxi11/E5810Reboot.c
cp ../vxi11/vxi11intr.rpcl .
rpcgen  vxi11intr.rpcl
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF drvVxi11.d  ../../asyn/vxi11/drvVxi11.c
../../asyn/vxi11/drvVxi11.c:41:23: error: vxi11core.h: No such file or directory
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF vxi11core_xdr.d  vxi11core_xdr.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF drvAsyn.d  ../../asyn/asynRecord/drvAsyn.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynRecord.d  ../../asyn/asynRecord/asynRecord.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynFloat64TimeSeries.d  ../../asyn/devEpics/devAsynFloat64TimeSeries.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynFloat64Array.d  ../../asyn/devEpics/devAsynFloat64Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynFloat32Array.d  ../../asyn/devEpics/devAsynFloat32Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynFloat64.d  ../../asyn/devEpics/devAsynFloat64.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynUInt32Digital.d  ../../asyn/devEpics/devAsynUInt32Digital.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynInt32TimeSeries.d  ../../asyn/devEpics/devAsynInt32TimeSeries.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynInt32Array.d  ../../asyn/devEpics/devAsynInt32Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynInt16Array.d  ../../asyn/devEpics/devAsynInt16Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynInt8Array.d  ../../asyn/devEpics/devAsynInt8Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynInt32.d  ../../asyn/devEpics/devAsynInt32.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynEpicsUtils.d  ../../asyn/devEpics/asynEpicsUtils.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devAsynOctet.d  ../../asyn/devEpics/devAsynOctet.c
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynPortDriver.d  ../../asyn/asynPortDriver/asynPortDriver.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF paramList.d  ../../asyn/asynPortDriver/paramList.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF paramVal.d  ../../asyn/asynPortDriver/paramVal.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF ParamValValueNotChanged.d  ../../asyn/asynPortDriver/exceptions/ParamValValueNotChanged.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF ParamValWrongType.d  ../../asyn/asynPortDriver/exceptions/ParamValWrongType.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF ParamValStringSizeRequestTooBig.d  ../../asyn/asynPortDriver/exceptions/ParamValStringSizeRequestTooBig.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF ParamValNotDefined.d  ../../asyn/asynPortDriver/exceptions/ParamValNotDefined.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF ParamListParamNotFound.d  ../../asyn/asynPortDriver/exceptions/ParamListParamNotFound.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF ParamListInvalidIndex.d  ../../asyn/asynPortDriver/exceptions/ParamListInvalidIndex.cpp
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInterposeFlush.d  ../../asyn/miscellaneous/asynInterposeFlush.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInterposeEos.d  ../../asyn/miscellaneous/asynInterposeEos.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInterposeCom.d  ../../asyn/miscellaneous/asynInterposeCom.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynShellCommands.d  ../../asyn/miscellaneous/asynShellCommands.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynStandardInterfacesBase.d  ../../asyn/interfaces/asynStandardInterfacesBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynCommonSyncIO.d  ../../asyn/interfaces/asynCommonSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynEnumSyncIO.d  ../../asyn/interfaces/asynEnumSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynEnumBase.d  ../../asyn/interfaces/asynEnumBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynGenericPointerSyncIO.d  ../../asyn/interfaces/asynGenericPointerSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynGenericPointerBase.d  ../../asyn/interfaces/asynGenericPointerBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynOctetSyncIO.d  ../../asyn/interfaces/asynOctetSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynOctetBase.d  ../../asyn/interfaces/asynOctetBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynFloat64ArraySyncIO.d  ../../asyn/interfaces/asynFloat64ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynFloat64ArrayBase.d  ../../asyn/interfaces/asynFloat64ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynFloat32ArraySyncIO.d  ../../asyn/interfaces/asynFloat32ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynFloat32ArrayBase.d  ../../asyn/interfaces/asynFloat32ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynFloat64SyncIO.d  ../../asyn/interfaces/asynFloat64SyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynFloat64Base.d  ../../asyn/interfaces/asynFloat64Base.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynUInt32DigitalSyncIO.d  ../../asyn/interfaces/asynUInt32DigitalSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynUInt32DigitalBase.d  ../../asyn/interfaces/asynUInt32DigitalBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt32ArraySyncIO.d  ../../asyn/interfaces/asynInt32ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt32ArrayBase.d  ../../asyn/interfaces/asynInt32ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt16ArraySyncIO.d  ../../asyn/interfaces/asynInt16ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt16ArrayBase.d  ../../asyn/interfaces/asynInt16ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt8ArraySyncIO.d  ../../asyn/interfaces/asynInt8ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt8ArrayBase.d  ../../asyn/interfaces/asynInt8ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt32SyncIO.d  ../../asyn/interfaces/asynInt32SyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynInt32Base.d  ../../asyn/interfaces/asynInt32Base.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF drvAsynIPServerPort.d  ../../asyn/drvAsynSerial/drvAsynIPServerPort.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF drvAsynIPPort.d  ../../asyn/drvAsynSerial/drvAsynIPPort.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF drvAsynSerialPort.d  ../../asyn/drvAsynSerial/drvAsynSerialPort.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynGpib.d  ../../asyn/asynGpib/asynGpib.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF epicsInterruptibleSyscall.d  ../../asyn/asynDriver/epicsInterruptibleSyscall.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynManager.d  ../../asyn/asynDriver/asynManager.c
make[2]: Leaving directory `/usr/local/epics/support/asyn/4-20/asyn/O.linux-x86_64'
Installing dbd file ../../dbd/drvAsynSerialPort.dbd
mkdir ../../dbd
Installing dbd file ../../dbd/drvAsynIPPort.dbd
Installing dbd file ../../dbd/asyn.dbd
Installing dbd file ../../dbd/devAsynOctet.dbd
Installing dbd file ../../dbd/devAsynInt32.dbd
Installing dbd file ../../dbd/devAsynInt8Array.dbd
Installing dbd file ../../dbd/devAsynInt16Array.dbd
Installing dbd file ../../dbd/devAsynInt32Array.dbd
Installing dbd file ../../dbd/devAsynInt32TimeSeries.dbd
Installing dbd file ../../dbd/devAsynUInt32Digital.dbd
Installing dbd file ../../dbd/devAsynFloat64.dbd
Installing dbd file ../../dbd/devAsynFloat32Array.dbd
Installing dbd file ../../dbd/devAsynFloat64Array.dbd
Installing dbd file ../../dbd/devAsynFloat64TimeSeries.dbd
Installing dbd file ../../dbd/devEpics.dbd
Installing dbd file ../../dbd/devAsynRecord.dbd
Installing dbd file ../../dbd/drvVxi11.dbd
Installing dbd file ../../dbd/drvNi1014.dbd
Installing dbd file ../../dbd/devGpib.dbd
Installing dbd file ../../dbd/asynRecord.dbd
Installing db file ../../db/asynInt32TimeSeries.db
mkdir ../../db
Installing db file ../../db/asynFloat64TimeSeries.db
Installing db file ../../db/asynRecord.db
Installing generic include file ../../include/asynDriver.h
mkdir ../../include
Installing generic include file ../../include/epicsInterruptibleSyscall.h
Installing generic include file ../../include/asynGpibDriver.h
Installing generic include file ../../include/drvAsynSerialPort.h
Installing generic include file ../../include/drvAsynIPPort.h
Installing generic include file ../../include/drvAsynIPServerPort.h
Installing generic include file ../../include/asynInt32.h
Installing generic include file ../../include/asynInt32SyncIO.h
Installing generic include file ../../include/asynUInt32Digital.h
Installing generic include file ../../include/asynUInt32DigitalSyncIO.h
Installing generic include file ../../include/asynFloat64.h
Installing generic include file ../../include/asynFloat64SyncIO.h
Installing generic include file ../../include/asynInt8Array.h
Installing generic include file ../../include/asynInt8ArraySyncIO.h
Installing generic include file ../../include/asynInt16Array.h
Installing generic include file ../../include/asynInt16ArraySyncIO.h
Installing generic include file ../../include/asynInt32Array.h
Installing generic include file ../../include/asynInt32ArraySyncIO.h
Installing generic include file ../../include/asynFloat32Array.h
Installing generic include file ../../include/asynFloat32ArraySyncIO.h
Installing generic include file ../../include/asynFloat64Array.h
Installing generic include file ../../include/asynFloat64ArraySyncIO.h
Installing generic include file ../../include/asynOctet.h
Installing generic include file ../../include/asynOctetSyncIO.h
Installing generic include file ../../include/asynGenericPointer.h
Installing generic include file ../../include/asynGenericPointerSyncIO.h
Installing generic include file ../../include/asynEnum.h
Installing generic include file ../../include/asynEnumSyncIO.h
Installing generic include file ../../include/asynCommonSyncIO.h
Installing generic include file ../../include/asynOption.h
Installing generic include file ../../include/asynDrvUser.h
Installing generic include file ../../include/asynStandardInterfaces.h
Installing generic include file ../../include/asynShellCommands.h
Installing generic include file ../../include/asynInterposeCom.h
Installing generic include file ../../include/asynInterposeEos.h
Installing generic include file ../../include/asynInterposeFlush.h
Installing generic include file ../../include/ParamListInvalidIndex.h
Installing generic include file ../../include/ParamListParamNotFound.h
Installing generic include file ../../include/ParamValNotDefined.h
Installing generic include file ../../include/ParamValStringSizeRequestTooBig.h
Installing generic include file ../../include/ParamValWrongType.h
Installing generic include file ../../include/ParamValValueNotChanged.h
Installing generic include file ../../include/asynParamType.h
Installing generic include file ../../include/paramVal.h
Installing generic include file ../../include/paramList.h
Installing generic include file ../../include/asynPortDriver.h
Installing generic include file ../../include/asynEpicsUtils.h
Installing generic include file ../../include/devGpib.h
Installing generic include file ../../include/devSupportGpib.h
Installing generic include file ../../include/devCommonGpib.h
Installing generated generic include file ../../include/asynRecord.h
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynDriver/asynManager.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynDriver/epicsInterruptibleSyscall.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynGpib/asynGpib.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/drvAsynSerial/drvAsynSerialPort.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/drvAsynSerial/drvAsynIPPort.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/drvAsynSerial/drvAsynIPServerPort.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt32Base.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt32SyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt8ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt8ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt16ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt16ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt32ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynInt32ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynUInt32DigitalBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynUInt32DigitalSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynFloat64Base.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynFloat64SyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynFloat32ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynFloat32ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynFloat64ArrayBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynFloat64ArraySyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynOctetBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynOctetSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynGenericPointerBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynGenericPointerSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynEnumBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynEnumSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynCommonSyncIO.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/interfaces/asynStandardInterfacesBase.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/miscellaneous/asynShellCommands.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/miscellaneous/asynInterposeCom.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/miscellaneous/asynInterposeEos.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/miscellaneous/asynInterposeFlush.c
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/exceptions/ParamListInvalidIndex.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/exceptions/ParamListParamNotFound.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/exceptions/ParamValNotDefined.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/exceptions/ParamValStringSizeRequestTooBig.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/exceptions/ParamValWrongType.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/exceptions/ParamValValueNotChanged.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/paramVal.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/paramList.cpp
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynPortDriver/asynPortDriver.cpp
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynOctet.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/asynEpicsUtils.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynInt32.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynInt8Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynInt16Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynInt32Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynInt32TimeSeries.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynUInt32Digital.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynFloat64.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynFloat32Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynFloat64Array.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devEpics/devAsynFloat64TimeSeries.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynRecord/asynRecord.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/asynRecord/drvAsyn.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c vxi11core_xdr.c
vxi11core_xdr.c: In function ‘xdr_Device_Link’:
vxi11core_xdr.c:11: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_AddrFamily’:
vxi11core_xdr.c:21: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_Flags’:
vxi11core_xdr.c:31: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_ErrorCode’:
vxi11core_xdr.c:41: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_Error’:
vxi11core_xdr.c:51: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Create_LinkResp’:
vxi11core_xdr.c:116: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_WriteParms’:
vxi11core_xdr.c:132: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_WriteResp’:
vxi11core_xdr.c:150: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_ReadResp’:
vxi11core_xdr.c:229: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_ReadStbResp’:
vxi11core_xdr.c:243: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_GenericParms’:
vxi11core_xdr.c:255: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_EnableSrqParms’:
vxi11core_xdr.c:334: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_LockParms’:
vxi11core_xdr.c:348: warning: unused variable ‘buf’
vxi11core_xdr.c: In function ‘xdr_Device_DocmdResp’:
vxi11core_xdr.c:445: warning: unused variable ‘buf’
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/vxi11/drvVxi11.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/vxi11/E5810Reboot.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/vxi11/E2050Reboot.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/vxi11/TDS3000Reboot.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devGpib/devCommonGpib.c
../../asyn/devGpib/devCommonGpib.c: In function ‘evFinish’:
../../asyn/devGpib/devCommonGpib.c:452: warning: unused variable ‘value’
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devGpib/devSupportGpib.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -c ../../asyn/devGpib/boSRQonOff.c
/usr/bin/ar -rc   libasyn.a        asynManager.o epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o drvAsynIPPort.o drvAsynIPServerPort.o asynInt32Base.o asynInt32SyncIO.o asynInt8ArrayBase.o asynInt8ArraySyncIO.o asynInt16ArrayBase.o asynInt16ArraySyncIO.o asynInt32ArrayBase.o asynInt32ArraySyncIO.o asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o asynFloat64ArrayBase.o asynFloat64ArraySyncIO.o asynOctetBase.o asynOctetSyncIO.o asynGenericPointerBase.o asynGenericPointerSyncIO.o asynEnumBase.o asynEnumSyncIO.o asynCommonSyncIO.o asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o asynInterposeEos.o asynInterposeFlush.o ParamListInvalidIndex.o ParamListParamNotFound.o ParamValNotDefined.o ParamValStringSizeRequestTooBig.o ParamValWrongType.o ParamValValueNotChanged.o paramVal.o paramList.o asynPortDriver.o devAsynOctet.o asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o devAsynInt16Array.o devAsynInt32Array.o devAsynInt32TimeSeries.o devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat32Array.o devAsynFloat64Array.o devAsynFloat64TimeSeries.o asynRecord.o drvAsyn.o vxi11core_xdr.o drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o devCommonGpib.o devSupportGpib.o boSRQonOff.o
/usr/bin/ranlib libasyn.a
rm -f libasyn.so.
/usr/bin/g++ -o libasyn.so. -shared -fPIC -Wl,-hlibasyn.so. -L/usr/local/epics/base-3.15.0.1/lib/linux-x86_64 -Wl,-rpath,/usr/local/epics/base-3.15.0.1/lib/linux-x86_64       -m64               asynManager.o epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o drvAsynIPPort.o drvAsynIPServerPort.o asynInt32Base.o asynInt32SyncIO.o asynInt8ArrayBase.o asynInt8ArraySyncIO.o asynInt16ArrayBase.o asynInt16ArraySyncIO.o asynInt32ArrayBase.o asynInt32ArraySyncIO.o asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o asynFloat64ArrayBase.o asynFloat64ArraySyncIO.o asynOctetBase.o asynOctetSyncIO.o asynGenericPointerBase.o asynGenericPointerSyncIO.o asynEnumBase.o asynEnumSyncIO.o asynCommonSyncIO.o asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o asynInterposeEos.o asynInterposeFlush.o ParamListInvalidIndex.o ParamListParamNotFound.o ParamValNotDefined.o ParamValStringSizeRequestTooBig.o ParamValWrongType.o ParamValValueNotChanged.o paramVal.o paramList.o asynPortDriver.o devAsynOctet.o asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o devAsynInt16Array.o devAsynInt32Array.o devAsynInt32TimeSeries.o devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat32Array.o devAsynFloat64Array.o devAsynFloat64TimeSeries.o asynRecord.o drvAsyn.o vxi11core_xdr.o drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o devCommonGpib.o devSupportGpib.o boSRQonOff.o    -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../lib/linux-x86_64/libasyn.so.
mkdir ../../lib
mkdir ../../lib/linux-x86_64
Installing library ../../lib/linux-x86_64/libasyn.a
make[1]: Leaving directory `/usr/local/epics/support/asyn/4-20/asyn'
make -C ./testApp install
make[1]: Entering directory `/usr/local/epics/support/asyn/4-20/testApp'
make -C ./src install
make[2]: Entering directory `/usr/local/epics/support/asyn/4-20/testApp/src'
perl -CSD /usr/local/epics/base-3.15.0.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install
make[3]: Entering directory `/usr/local/epics/support/asyn/4-20/testApp/src/O.linux-x86_64'
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF asynExample.d  ../asynExample.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF interposeInterface.d  ../interposeInterface.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF devTestBlock.d  ../devTestBlock.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF addrChangeDriver.d  ../addrChangeDriver.c
/usr/bin/gcc  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64     -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF echoDriver.d  ../echoDriver.c
/usr/bin/g++  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3   -Wall      -m64      -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include    -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc -I/usr/local/epics/base-3.15.0.1/include/os/Linux -I/usr/local/epics/base-3.15.0.1/include       -MM -MF testMain.d  ../testMain.cpp
Expanding dbd file ../testInclude.dbd
perl -CSD /usr/local/epics/base-3.15.0.1/bin/linux-x86_64/dbdExpand.pl  -I. -I.. -I../O.Common -I../../../dbd -I/usr/local/epics/base-3.15.0.1/dbd -o test.dbd ../testInclude.dbd
Duplicate name 'asynRegister'
Context: file '../../../dbd/asyn.dbd' in file '../../../dbd/drvAsynSerialPort.dbd' in file '../testInclude.dbd'
make[3]: Leaving directory `/usr/local/epics/support/asyn/4-20/testApp/src/O.linux-x86_64'
Installing dbd file ../../../dbd/devTestBlock.dbd
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/usr/local/epics/support/asyn/4-20/testApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/local/epics/support/asyn/4-20/testApp'
make: *** [testApp.install] Error 2
RE: Error building asyn4-20 on CentOS 6.3 Mark Rivers
Re: Error building asyn4-20 on CentOS 6.3 Andrew Johnson
Prev: 3.14 v.s. 3.15 vs. v4 Richard Farnsworth
Next: RE: Error building asyn4-20 on CentOS 6.3 Mark Rivers
Prev: Re: Utilities for EPICS on Multi-Core Linux Ralph Lange
