Hi Andre,
I hope you realize that Base 3.15.0.1 is a development release that should not
be used for operational systems. It may cause build problems like the ones
you've reported with external modules that have not yet been modified to work
with it. Unless you are particularly wanting to try out the new features you
might find it easier to use the 3.14.12.2 release for learning EPICS.
- Andrew
On 2012-11-26 Andre Charbonneau wrote:
> Greetings,
> I have been trying to build the following asyn driver on my CentOS 6.3
> (64bit) linux system but with no luck:
> http://www.aps.anl.gov/epics/download/modules/asyn4-20.tar.gz
> First I found out a patch that needed to be applied to the code:
> http://www.aps.anl.gov/epics/tech-talk/2012/msg01794.php
> Then the make went a bit further but then it ends with the following error:
> <... snip ...>
> /usr/bin/g++ -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux
> -D_REENTRANT -O3 -Wall -m64 -I. -I../O.Common -I. -I.
> -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux
> -I../../../include
> -I/usr/local/epics/base-3.15.0.1/include/compiler/gcc
> -I/usr/local/epics/base-3.15.0.1/include/os/Linux
> -I/usr/local/epics/base-3.15.0.1/include -MM -MF testMain.d
> ../testMain.cpp
> Expanding dbd file ../testInclude.dbd
> perl -CSD /usr/local/epics/base-3.15.0.1/bin/linux-x86_64/dbdExpand.pl
> -I. -I.. -I../O.Common -I../../../dbd
> -I/usr/local/epics/base-3.15.0.1/dbd -o test.dbd ../testInclude.dbd
> Duplicate name 'asynRegister'
> Context: file '../../../dbd/asyn.dbd' in file
> '../../../dbd/drvAsynSerialPort.dbd' in file '../testInclude.dbd'
> make[3]: Leaving directory
> `/usr/local/epics/support/asyn/4-20/testApp/src/O.linux-x86_64'
> make[3]: Entering directory
> Installing dbd file ../../../dbd/devTestBlock.dbd
> make[2]: *** [install.linux-x86_64] Error 2
> make[2]: Leaving directory `/usr/local/epics/support/asyn/4-20/testApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `/usr/local/epics/support/asyn/4-20/testApp'
> make: *** [testApp.install] Error 2
> From the output above, I'm not sure what the error is.
> (I'm an EPICS newbie, so I'm probably missing something pretty obvious.)
> I've attached the full make output.
> Anyone else experienced a similar error before?
> Thanks,
> Andre
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
- Re: Error building asyn4-20 on CentOS 6.3 Andre Charbonneau
- Error building asyn4-20 on CentOS 6.3 Andre Charbonneau
Re: Error building asyn4-20 on CentOS 6.3 Ralph Lange
usb over ethernet John William Sinclair
<2012>
2025
2026
<2012>
2025
2026
