1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Using CSS and setting up RDB Archiver
Date: Fri, 30 Nov 2012 14:11:58 -0500
I seem to be missing some necessary files for the RDB archiver to run properly.  I get the following errors when trying to run org.csstudio.archiver.engine/ArchiveEngine.product (see below).  I found org.eclipse.equinox.http.jetty8 in the eclipse equinox repository and downloaded it, but I'm still getting the error.  Perhaps I needed more than just that one package?  Any help would be appreciated.
Thank you!
James
!SESSION 2012-11-30 13:56:59.962 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_37
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -product org.csstudio.archive.engine.engine
Command-line arguments:  -product org.csstudio.archive.engine.engine -data /home/sysuser/CSS/cssTest/css-nsls2/workspace/../runtime-ArchiveEngine.product -dev file:/home/sysuser/CSS/cssTest/css-nsls2/workspace/.metadata/.plugins/org.eclipse.pde.core/ArchiveEngine.product/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.app 0 0 2012-11-30 13:57:00.518
!MESSAGE Product org.csstudio.archive.engine.engine could not be found.
!ENTRY org.eclipse.osgi 2 0 2012-11-30 13:57:00.551
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.551
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841.jar was not resolved.
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.551
!MESSAGE Missing imported package org.eclipse.jetty.util.component_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.552
!MESSAGE Missing imported package org.eclipse.jetty.server.nio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.util.log_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.553
!MESSAGE Missing imported package org.eclipse.jetty.io.nio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.handler_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.554
!MESSAGE Missing imported package org.eclipse.jetty.server.ssl_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.bio_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server.session_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.servlet_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.server_[8.0.0,9.0.0).
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.555
!MESSAGE Missing imported package org.eclipse.jetty.util_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.http_[8.0.0,9.0.0).
!MESSAGE Missing imported package org.eclipse.jetty.io.bio_[8.0.0,9.0.0).
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.555
!MESSAGE Bundle initial@reference:file:../../../home/sysuser/CSS/cssTest/css-nsls2/plugins/org.csstudio.archive.rdb_3.1.1.201211061437.jar was not resolved.
!SUBENTRY 2 org.csstudio.archive.rdb 2 0 2012-11-30 13:57:00.555
!MESSAGE Missing required bundle org.eclipse.help_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2012-11-30 13:57:00.566
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.566
!MESSAGE Bundle org.csstudio.utility.httpd_1.0.0.qualifier [3] was not resolved.
!SUBENTRY 2 org.csstudio.utility.httpd 2 0 2012-11-30 13:57:00.566
!MESSAGE Missing required bundle org.eclipse.equinox.http.jetty_0.0.0.
!MESSAGE Bundle org.eclipse.equinox.http.jetty_3.0.0.v20120522-1841 [23] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.566
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.567
!SUBENTRY 2 org.eclipse.equinox.http.jetty 2 0 2012-11-30 13:57:00.568
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.568
!MESSAGE Bundle org.csstudio.archive.config.rdb_1.0.0.qualifier [24] was not resolved.
!SUBENTRY 2 org.csstudio.archive.config.rdb 2 0 2012-11-30 13:57:00.568
!MESSAGE Missing required bundle org.csstudio.archive.rdb_3.0.1.
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.569
!MESSAGE Bundle org.csstudio.archive.rdb_3.1.1.201211061437 [26] was not resolved.
!SUBENTRY 2 org.csstudio.archive.rdb 2 0 2012-11-30 13:57:00.569
!MESSAGE Bundle org.csstudio.archive.writer.rdb_1.0.0.qualifier [28] was not resolved.
!SUBENTRY 2 org.csstudio.archive.writer.rdb 2 0 2012-11-30 13:57:00.570
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-11-30 13:57:00.572
!MESSAGE Bundle org.csstudio.archive.engine_3.0.1.qualifier [31] was not resolved.
!SUBENTRY 2 org.csstudio.archive.engine 2 0 2012-11-30 13:57:00.573
!MESSAGE Missing required bundle org.csstudio.utility.httpd_1.0.0.
!ENTRY org.eclipse.osgi 4 0 2012-11-30 13:57:00.573
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
    at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
    at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
    at java.lang.reflect.Method.invoke(Method.java:597)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
On Thu, Nov 29, 2012 at 4:02 PM, Kasemir, Kay <[email protected]> wrote:
For the record, turned out to be the tool.
The *.product file won't open in CSS itself nor in a plain JEE version of Eclipse.
-Kay
From: James F Ross <[email protected]<mailto:[email protected]>>
Date: Thursday, November 29, 2012 16:01
To: Kasemir Kay <[email protected]<mailto:[email protected]>>
There we go.  It looks like I had the wrong version of eclipse installed.  It is opening .product properly now with eclipse 3.7.0 for RCP/RAP development.
Thanks very much!
James
On Thu, Nov 29, 2012 at 1:45 PM, Kasemir, Kay <[email protected]<mailto:[email protected]>> wrote:
Hi:
>The issue is, when I open the .product file it should open the eclipse product editor window, allowing me to synchronize and launch the eclipse application.  >However, all it does when I double click on it is open the file, displaying the source code.
Do you have the Eclipse 3.7(.2) IDE for RCP/RAP development, and in there you're trying to open the product file?
Then maybe you have once opened it as a text file, so you'll have to right-click on the product file and select Open With.../Product editor to make it default to the product editor again.
For more detail than in the Jlab wiki see http://cs-studio.sourceforge.net/docbook/css_book.pdf
-Kay
Re: Using CSS and setting up RDB Archiver Kasemir, Kay
Prev: DBE_PROPERTY and CSS Re: Using CAJ in production (DBE_PROPERTY and CA gateway) Kasemir, Kay
Next: EPICS support for NewFocus 8752 controller? Fairley, Diane M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Using CSS and setting up RDB Archiver Kasemir, Kay
Next: Re: Using CSS and setting up RDB Archiver Kasemir, Kay
