1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DBE_PROPERTY and CSS Re: Using CAJ in production (DBE_PROPERTY and CA gateway)
To: "Kasemir, Kay" <[email protected]>
Date: Fri, 30 Nov 2012 16:41:42 -0500
On 11/30/2012 12:50 PM, Kasemir, Kay wrote:
On 11/30/12 12:30 , "Andrew Johnson" <[email protected]> wrote:
4) Why does CSS delete the monitor before issuing a put?
That is an interesting question...
Not sure what that means. Who saw that happening where?
Me observing with wireshark.
With CSS "Probe"
Both Probe and BOY.
or ..? Talking to an older IOC or one that supports DBE_PROPERTY? Using a
gateway or not?
The IOC (and gateway) were build against Base 3.14.11. Direct connection to the IOC works. From my memory, the CA gateway was not forwarding the monitor create request at all, so the IOC version makes no difference in this case.
So by default we disabled the DBE_PROPERTY support. It's a CSS preference
setting.
Unfortunately we seem to have a css distribution version (css-nsls2 3.1.2) where this defaults to enabled and can't be disabled :(
I suspect we will pick up the improved behavior you describe in our next upgrade.
Michael
DBE_PROPERTY and CSS Re: Using CAJ in production (DBE_PROPERTY and CA gateway) Kasemir, Kay
Prev: RE: caRepeater object code not cross-compiled in R3.14.12.2 Hu, Yong
Next: mbuf depletion on vxWorks 5.5.2 with VME5100 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: DBE_PROPERTY and CSS Re: Using CAJ in production (DBE_PROPERTY and CA gateway) Kasemir, Kay
Next: Using CSS and setting up RDB Archiver James F Ross
