> Hi, Matej.
> OK, if CA expects the short hostname, why is that not the default in
> CAJ? Why even provide the CAJ_STRIP_HOSTNAME system property? If there
> is a dot in the name, just drop it and everything after it.
CAJ default is SHN, however under some circumstances it can return FQDN.
At that time we decided to go that way (and not be smart in CAJ code).
java.net.InetAddress.getLocalHost().getHostName() is used to get host name.
I gets more interesting if you have more that one IF installed (Java 6
new API helps here).
Calling System.exec("hostname") is not a good way to get it.
Matej
- Re: Using CAJ in production J. Lewis Muir
- Using CAJ in production Shankar, Murali
- Re: Using CAJ in production Matej Sekoranja
Re: mask for bitwise operation in CALC record haquin
waveform put in CSS Pavel Maslov
<2012>
2025
2026
<2012>
2025
2026
