Subject: waveform put in CSS
To: EPICS Tech Talk <[email protected]>
Date: Mon, 3 Dec 2012 16:38:04 +0400
Hello, guys
Is there a chance I could edit the waveform record in CSS in the same way as using caput with the "-a" parameter:
caput -a agilent1:userWF 5 -5000 -4000  -3000 -2000 -1000
I can get a waveform using the XY Graph or Text Update widgets. However, if I want to put data in the record, it doesn't work for me.
Any ideas?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
RE: waveform put in CSS Hu, Yong
RE: waveform put in CSS Steiner, Mathias
Prev: Re: Using CAJ in production Matej Sekoranja
Next: Job opening at PSI Dirk Zimoch
Prev: mbuf depletion on vxWorks 5.5.2 with VME5100 Mark Rivers
Next: RE: waveform put in CSS Hu, Yong
