Subject: RE: waveform put in CSS
To: "'Pavel Maslov'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Mon, 3 Dec 2012 14:12:33 +0000
It seems that the Array widget in BOY Version 3.1.1 and higher will do the job although I haven’t tried this feature. See [1] and give a try.
Yong
[1] http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/ChangeLog.html#3.1.1
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Maslov
Sent: Monday, December 03, 2012 7:38 AM
To: EPICS Tech Talk
Subject: waveform put in CSS
Hello, guys
Is there a chance I could edit the waveform record in CSS in the same way as using caput with the "-a" parameter:
caput -a agilent1:userWF 5 -5000 -4000  -3000 -2000 -1000
I can get a waveform using the XY Graph or Text Update widgets. However, if I want to put data in the record, it doesn't work for me.
Any ideas?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
RE: waveform put in CSS Chen, Xihui
waveform put in CSS Pavel Maslov
Prev: Job opening at PSI Dirk Zimoch
Next: Re: Using CSS and setting up RDB Archiver Kasemir, Kay
Prev: waveform put in CSS Pavel Maslov
Next: RE: waveform put in CSS Chen, Xihui
