1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: waveform put in CSS
To: "Hu, Yong" <[email protected]>, "'Pavel Maslov'" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 4 Dec 2012 09:08:47 -0500
Yes, as Yong mentioned, array is the best way to put data to a waveform. If the waveform is very short, you can also directly put data to the waveform with Text Input widget with the format like “-5000 -4000  -3000 -2000 -1000” See http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/widgets/TextInput.html
Xihui
Sent: Monday, December 03, 2012 9:13 AM
To: 'Pavel Maslov'; EPICS Tech Talk
It seems that the Array widget in BOY Version 3.1.1 and higher will do the job although I haven’t tried this feature. See [1] and give a try.
Yong
[1] http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/ChangeLog.html#3.1.1
From: [email protected] [mailto:[email protected]] On Behalf Of Pavel Maslov
Sent: Monday, December 03, 2012 7:38 AM
To: EPICS Tech Talk
Subject: waveform put in CSS
Hello, guys
Is there a chance I could edit the waveform record in CSS in the same way as using caput with the "-a" parameter:
caput -a agilent1:userWF 5 -5000 -4000  -3000 -2000 -1000
I can get a waveform using the XY Graph or Text Update widgets. However, if I want to put data in the record, it doesn't work for me.
Any ideas?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
waveform put in CSS Pavel Maslov
RE: waveform put in CSS Hu, Yong
Prev: Re: Missing symbol cannel archiver Kasemir, Kay
Next: Re: Using CAJ in production Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: waveform put in CSS Hu, Yong
Next: RE: waveform put in CSS Steiner, Mathias
