Subject: Re: Converting raw to eng in a waveform
Cc: Kim Changseung <[email protected]>
Date: Wed, 05 Dec 2012 14:49:45 -1000
Hi Franck,
in a similar application (reading out Optomuxes) we use one
calc record per channel that converts from Optomux readout
numbers to temperatures. The slopes and intercepts are
pvLoaded at boot time (but of course can be pvloaded again
any time later as well).
Maren
Di Maio Franck wrote:
Dear all
We have a question about implementing device support for an ADC that returns values in a waveform record, not using asyn.
If we want the data to be converted from the ADC voltage range into user's engineering data, we need engineering limits or scaling factors or...
Seems that waveform is not as detailed as ai for that.
I guess that we are not the only one in the globe having this issue.
I'll appreciate to have some indication on the implementation.
Converting raw to eng in a waveform Di Maio Franck
Prev: RE: Converting raw to eng in a waveform Hill, Jeff
Next: Re: waveform put in CSS Pavel Maslov
Next: stable Linux distribution for EPICS Pavel Maslov
