Subject: Re: waveform put in CSS
To: "Steiner, Mathias" <[email protected]>
Date: Thu, 6 Dec 2012 18:29:02 +0400
Thank you all!
On Tue, Dec 4, 2012 at 11:54 PM, Steiner, Mathias <[email protected]> wrote:
I can't find the email that contained the most recent answer... it said to look at this page:
http://cs-studio.hg.sourceforge.net/hgweb/cs-studio/cs-studio-3.1/raw-file/tip/applications/plugins/org.csstudio.opibuilder/html/widgets/TextInput.html
Anyway, one can use "Text Update" to display the waveform string, but it is necessary to select format "String" to see the text.  Selecting "Default" will show the elements in ASCII format.
"Text Input" also displays the text, and also gives a choice of "String" or "Default."
Very nice and useful.
Cheers -Mathias
Mathias Steiner
Beam Coordinator
NSCL/Michigan State University
>> Is there a chance I could edit the waveform record in CSS in the same way as using caput...
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
waveform put in CSS Pavel Maslov
RE: waveform put in CSS Steiner, Mathias
Prev: Re: Converting raw to eng in a waveform Maren Purves
Next: stable Linux distribution for EPICS Pavel Maslov
Prev: RE: waveform put in CSS Steiner, Mathias
Next: Job opening at PSI Dirk Zimoch
