Not so fast, Mr Kim :]] As a side note: I was using this device support on the Tektronix TDS3054C scope. However, I didn't have medm installed, or better say, I didn't know how to use it at the time. So I converted the operator screens into CSS BOY panels. And I didn't have any problems with the waveform plots, except for that I had to set the EPICS_CA_MAX_ARRAY_BYTES env. variables both on the IOC and client machines.
I haven't understood from your answer, but can you caget the waveform PV? Does it contain any data? On Fri, Dec 7, 2012 at 3:50 PM, Yujong Kim <[email protected]> wrote:
Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Landline: +7 (812) 461 01 01
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
