Subject: Re: Tektronix 3014 Tracing Problem
To: Trevor Downer <[email protected]>
Cc: Yujong Kim <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Fri, 7 Dec 2012 20:33:55 -0800
Is the scope triggering?
On Dec 7, 2012, at 5:35 PM, Trevor Downer <[email protected]> wrote:
> Hello again!
> We were able to get the cartesian plot function to work.
> I attached a screenshot of the display after our success.
> Thanks for your help with that!
> The problem was with the MEDM installation, so I re-installed MEDM.
> We were able to make a cartesian plot correctly using another application.
> However, we still are not getting the trace data from the oscilloscope.
> I attached screenshot is of the result that I get when I run the caget
> command on one of the wave form records.
> This is the same result that I get for the other waveform records as well.
> We tried changing the EPICS_CA_MAX_ARRAY_BYTES variable in the
> environment, the envParams, and the st.cmd script from 10000 to
> 100000000, but to no avail as we are still not able to get a trace.
> We also tried changing the NELM field in the waveform records from
> 10000 to 100000 and bigger, and we had the same result.
> Any help that you can give us would be greatly appreciated!
> Thanks
> On Fri, Dec 7, 2012 at 12:10 PM, Hartman, Steven M. <[email protected]> wrote:
>> On Dec 6, 2012, at 11:51 PM, Yujong Kim wrote:
>>> We can control all main functions of the scope from EPICS MEDM OPI panels without any problem.
>> Hi Yujong--
>> To isolate whether this is an medm configuration issue or a CA configuration issue (e.g., EPICS_CA_MAX_ARRAY_BYTES), try to caget the waveform from the computer running medm.
>> Steven Hartman
>> [email protected]
> <chan2ScaledWaveWF.png><oscope_with_cartesian.png>
Eric Norum
[email protected]
Re: Tektronix 3014 Tracing Problem Pavel Maslov
Tektronix 3014 Tracing Problem Trevor Downer
Re: Tektronix 3014 Tracing Problem Eric Norum
Re: Tektronix 3014 Tracing Problem Yujong Kim
Re: Tektronix 3014 Tracing Problem Hartman, Steven M.
Re: Tektronix 3014 Tracing Problem Trevor Downer
Prev: Re: Tektronix 3014 Tracing Problem Trevor Downer
Next: Re: Tektronix 3014 Tracing Problem Pavel Maslov
