1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Tektronix 3014 Tracing Problem
To: Eric Norum <[email protected]>
Cc: Yujong Kim <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Sat, 8 Dec 2012 08:49:38 +0100
> Is the scope triggering?
like :]]
Yeah, what's on the scope at the moment you take an medm screenshot?
Can you run the following on the client machine:
echo $EPICS_CA_MAX_ARRAY_BYTES
cainfo scopeTest:chan2scaledWF
caget scopeTest:chan2scaledWF
and send us the output?
It seems, since you are not able to get the waveform via caget, you won''t have it on the plot either (from what I can see you have zeros in the wf record, however this may also mean you haven't got your scope triggered, good point by Eric!).
Also, try to reach the scope via web-browser and take a screenshot of the scope screen.
From you screenshot I can see that you have time base 10ns, delay 1.36 ms, and TrigLevel 9.8Volts. Unless you manually trigger the scope (via button on the front panel), it doesn't seem reasonable to have such a high trigger level. Note aslo, that on the medm panel you have time base in microseconds.
On Dec 7, 2012, at 5:35 PM, Trevor Downer <[email protected]> wrote:
> Hello again!
> We were able to get the cartesian plot function to work.
> I attached a screenshot of the display after our success.
> Thanks for your help with that!
> The problem was with the MEDM installation, so I re-installed MEDM.
> We were able to make a cartesian plot correctly using another application.
> However, we still are not getting the trace data from the oscilloscope.
> I attached screenshot is of the result that I get when I run the caget
> command on one of the wave form records.
> This is the same result that I get for the other waveform records as well.
> We tried changing the EPICS_CA_MAX_ARRAY_BYTES variable in the
> environment, the envParams, and the st.cmd script from 10000 to
> 100000000, but to no avail as we are still not able to get a trace.
> We also tried changing the NELM field in the waveform records from
> 10000 to 100000 and bigger, and we had the same result.
> Any help that you can give us would be greatly appreciated!
> Thanks
> On Fri, Dec 7, 2012 at 12:10 PM, Hartman, Steven M. <[email protected]> wrote:
>> On Dec 6, 2012, at 11:51 PM, Yujong Kim wrote:
>>> We can control all main functions of the scope from EPICS MEDM OPI panels without any problem.
>> Hi Yujong--
>> To isolate whether this is an medm configuration issue or a CA configuration issue (e.g., EPICS_CA_MAX_ARRAY_BYTES), try to caget the waveform from the computer running medm.
>> Steven Hartman
>> [email protected]
> <chan2ScaledWaveWF.png><oscope_with_cartesian.png>
Eric Norum
[email protected]
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Tektronix 3014 Tracing Problem Trevor Downer
Re: Tektronix 3014 Tracing Problem Eric Norum
Re: Tektronix 3014 Tracing Problem Pavel Maslov
Re: Tektronix 3014 Tracing Problem Yujong Kim
Re: Tektronix 3014 Tracing Problem Hartman, Steven M.
Re: Tektronix 3014 Tracing Problem Trevor Downer
Prev: Re: Tektronix 3014 Tracing Problem Eric Norum
Next: Re: Utilities for EPICS on Multi-Core Linux Jack Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Tektronix 3014 Tracing Problem Nicholas P. DiMonte
