Subject: ca patch
To: "Davidsaver, Michael" <[email protected]>, "'tech-talk'" <[email protected]>
Date: Mon, 10 Dec 2012 16:10:06 -0500
 From 0b5c0803d8facca0693457dfc9aa7296df0543d2 Mon Sep 17 00:00:00 2001
Date: Mon, 10 Dec 2012 16:07:02 -0500
Subject: c++ build fix for gcc 4.7
 Storage/ListIndex.cpp |    9 ++++-----
 Storage/RTree.cpp     |    6 ++++--
 Tools/AVLTree.h       |   12 +++++++++---
 Tools/AVLTreeTest.cpp |   20 ++++++++++++--------
 4 files changed, 29 insertions(+), 18 deletions(-)
diff --git a/Storage/ListIndex.cpp b/Storage/ListIndex.cpp
index 6b83635..3d23c37 100644
--- a/Storage/ListIndex.cpp
+++ b/Storage/ListIndex.cpp
@@ -139,11 +139,10 @@ class RTree *ListIndex::getTree(const stdString &channel,
     return 0;
-int sort_compare(const stdString &a,
-                 const stdString &b)
-    return b.compare(a);
+template<> struct ItemOps<stdString> {
+	static int compare(const stdString &a, const stdString &b)
+	{   return b.compare(a); }
 void ListIndex::name_traverser(const stdString &name,
                                void *self)
diff --git a/Storage/RTree.cpp b/Storage/RTree.cpp
index ebc6aec..4830b45 100644
--- a/Storage/RTree.cpp
+++ b/Storage/RTree.cpp
@@ -409,8 +409,10 @@ bool RTree::selfTest(unsigned long &nodes, unsigned long &records)
 // Comparison routine for AVLTree (node_cache)
-int sort_compare(const RTree::Node &a, const RTree::Node &b)
-{    return b.offset - a.offset; }
+template<> struct ItemOps<RTree::Node> {
+	static int compare(const RTree::Node &a, const RTree::Node &b)
+	{   return b.offset - a.offset; }
 void RTree::read_node(Node &node) const
diff --git a/Tools/AVLTree.h b/Tools/AVLTree.h
index c0a5222..0a1fdbf 100644
--- a/Tools/AVLTree.h
+++ b/Tools/AVLTree.h
@@ -15,6 +15,12 @@
 #include <GenericException.h>
 #include <AutoFilePtr.h>
+template<class Item>
+struct ItemOps {
+  //static int compare(const Item& a, const Item& b) {return a-b;}
+  //static const char *tostr(const Item &) {return "hi";}
 // Tree Item:
 // Holds the full Item as well as left/right pointers
 template<class Item> class AVLItem
@@ -77,7 +83,7 @@ public:
         int comp;
         while (n)
-            comp = sort_compare(item, n->item);
+            comp = ItemOps<Item>::compare(item, n->item);
             if (comp == 0)
                 item = n->item;
@@ -165,7 +171,7 @@ private:
             *node = new_node;
             return true;
-        int comp = sort_compare(new_node->item, (*node)->item);
+        int comp = ItemOps<Item>::compare(new_node->item, (*node)->item);
         if (comp == 0)
         {   // Don't insert new node, only update data item
             (*node)->item = new_node->item;
@@ -217,7 +223,7 @@ private:
         ++i;
         int me = i;
         fprintf(f, "n%d [ label=\"%s (%d)\" ];\n",
-                me, toString(node->item), (int)node->balance);
+                me, ItemOps<Item>::tostr(node->item), (int)node->balance);
         if (node->left)
             fprintf(f, "n%d -> n%d\n", me, i+1);
diff --git a/Tools/AVLTreeTest.cpp b/Tools/AVLTreeTest.cpp
index 4d48933..f423152 100644
--- a/Tools/AVLTreeTest.cpp
+++ b/Tools/AVLTreeTest.cpp
@@ -1,11 +1,10 @@
 #include <stdlib.h>
+#include <stdio.h>
 #include "AVLTree.h"
 #include "UnitTest.h"
-static int sort_compare(const int &a, const int &b)
-{   return b-a; }
 static int avl_last_number;
 static bool tree_is_ordered;
@@ -17,12 +16,17 @@ static void avl_order_test(const int &i, void *)
     avl_last_number = i;
-static const char *toString(const int &i)
-    static char txt[10];
-    sprintf(txt, "%d", i);
-    return txt;
+template<> struct ItemOps<int> {
+	static int compare(const int &a, const int &b)
+	{   return b-a; }
+	static const char *tostr(const int &i)
+	    static char txt[10];
+	    sprintf(txt, "%d", i);
+	    return txt;
 TEST_CASE avl_test()
1.7.10.4
Prev: James Rowland mark.heron
Next: Passive Scanning processing Diego Sanz
