Subject: LeCroy DSO using VXI
To: EPICS Tech Talk <[email protected]>
Date: Wed, 12 Dec 2012 16:25:26 +0100
Hello,
I'm running into a problem trying to access a LeCrow WR640Zi DSO using its LXI interface.
In st.cmd I have:
vxi11Configure("osc","192.168.0.1",0,0.0,"inst0",0,0)
asynSetTraceMask("osc",3,0xff)
In XStream.proto:
identify {
	out "*IDN?";
	in "%s";
  @init {
		out "*IDN?";
		in "%s";
And in my db file:
record (stringin, "OSC:identify")
  field (DTYP, "stream")
  field (INP, "@XStream.proto identify $(interface)")
If I start my IOC under Linux, I get the following output:
#!../../bin/linux-x86/crpc
< envPaths
epicsEnvSet("ARCH","linux-x86")
epicsEnvSet("IOC","ioccrpc")
epicsEnvSet("TOP","/aaa/apps")
epicsEnvSet("EPICS_BASE","/aaa/base-3.14.12.2")
epicsEnvSet("ASYN","/aaa/modules/src/asyn4-20")
epicsEnvSet("STREAM_PROTOCOL_PATH","/aaa/apps/protocols")
cd /aaa/apps
dbLoadDatabase "dbd/crpc.dbd"
crpc_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadRecords "db/LeCroy.db"
cd /aaa/apps/iocBoot/ioccrpc
iocInit
Starting iocInit
## EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$
## EPICS Base built Jul 12 2012
2012/12/12 14:30:54.111 osc -1 registerInterruptUser
2012/12/12 14:30:54.112 osc -1 registerInterruptUser
2012/12/12 14:30:54.112 osc addr -1 queueRequest priority 3 not lockHolder
2012/12/12 14:30:57.619 osc vxi11 clientCall errno Permission denied clnt_stat 5
2012/12/12 14:30:57.619 osc vxiCreateIrqChannel (create_intr_chan): RPC: Timed out
2012/12/12 14:30:57.619 osc Warning -- SRQ not operational.
2012/12/12 14:31:01.623 osc vxi11 clientCall errno Success clnt_stat 5
osc vxiSrqEnable RPC error : RPC: Timed out
2012/12/12 14:31:01.623 osc asynGpib:pollAddr srqEnable
2012/12/12 14:31:01.623 osc asynGpib:srqHappened
2012/12/12 14:31:01.623 osc addr -1 queueRequest priority 1 not lockHolder
2012/12/12 14:31:01.623 asynManager connect queueCallback port:osc
2012/12/12 14:31:01.623 osc addr -1 queueRequest priority 0 not lockHolder
2012/12/12 14:31:01.623 osc schedule queueRequest timeout
2012/12/12 14:31:01.623 asynManager::portThread port=osc callback
2012/12/12 14:31:01.623 osc -1 vxiWrite numchars 5
2012/12/12 14:31:05.627 osc vxi11 clientIoCall errno Success clnt_stat 5
2012/12/12 14:31:05.627 osc CBM:HZDR:OSC:identify: asynError in write: osc RPC failed
2012/12/12 14:31:05.627 _main_ OSC:identify: @init handler failed
2012/12/12 14:31:05.627 _main_ OSC:identify: Record initialization failed
Here the Error messages fro clientCall and clientIOCall are missleading, as drvVxi11.c uses strerror instead of clnt_sperrno to print the rpc related error message from the return value of clnt_call(). Insted it should always read : Timeout.
I'm using base 3.14.12.2 and asyn 4.20.
In the log of the scope I see that it recieves the *IDN? query, and that it also sends the correct return string. Probably due to the fat, that it did ot set up the SRQ handler on the socket correctly.
Has anybody an idea how to debug this further? I have seen in the archive the recommendation to use an IOC on the scope directly (Win7) using the supplied ActiveX program to access thescope software. But I prefere the IOC externaly, as I had to install an AV Software on the scope to be allowed to include it in our network which consumes quite a bit of CPU.
Joern
Re: LeCroy DSO using VXI Nicholas P. DiMonte
Re: LeCroy DSO using VXI Eric Norum
Prev: Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
Next: Re: LeCroy DSO using VXI Nicholas P. DiMonte
Prev: Re: .PACT .TIME Rolf Keitel
