1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: "Connection refused" when running Ethernet/RS232 application
To: "'Nicholas P. DiMonte'" <[email protected]>, 张德敏 <[email protected]>
Date: Wed, 12 Dec 2012 16:00:33 +0000
You should be able to debug this using “telnet” from your Linux machine.
What happens if you do:
telnet 192.168.0.21 1
Do you also get connection refused?
From: [email protected] [mailto:[email protected]] On Behalf Of Nicholas P. DiMonte
Sent: Wednesday, December 12, 2012 9:12 AM
To:
张德敏
Cc: tech-talk
Subject: Re: "Connection refused" when running Ethernet/RS232 application
How do you have your LAN/Rs232 port configured? When I use a Moxa LAN/Rs232 converter I have to configure each port to "TCP Server Mode" for Asyn to work. I have seen error messages similar to yours when the port is not configured correctly.
Nick D.
On 12/12/2012 1:31 AM, 张德敏 wrote:
Hello everyone,
I'm using an Ethernet/232 converter which communicates between IOC and the RS232 device , and specify the Internet host and port numper like :
drvAsynIPPortConfigure("L0","192.168.0.21:1",0,0,0). Then running the application, it occurs:
  [fel@fel iocPSM6003]$ ../../bin/linux-x86/PSM6003 st.cmd
#!../../bin/linux-x86/PSM6003
## You may have to change PSM6003 to something else
## everywhere it appears in this file
##< envPaths
##cd ${TOP}
dbLoadDatabase("../../dbd/PSM6003.dbd",0,0)
PSM6003_registerRecordDeviceDriver(pdbbase)
## Load record instances
dbLoadRecords("../../db/psm6003.db","user=felHost")
##dbLoadRecords("../../db/psm6003.db","P=PSM6003:,R=,L=0,A=0")
##drvAsynIPPortConfigure("L0","127.0! .0.1",0,0,0)
##drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
##asynSetOption("L0",-1,"baud","9600")
##asynSetOption("L0",-1,"bits","8")
##asynSetOption("L0",-1,"parity","none")
##asynSetOption("L0",-1,"stop","1")
##asynSetOption("L0",-1,"clocal","Y")
##asynSetOption("L0",-1,"crtscts","N")
##asynOctetSetInputEos("L0",-1,"\n")
##asynOctetSetOutputEos("L0",-1,"\n")
##cd ${TOP}/iocBoot/${IOC}
iocInit()
Starting iocInit
## EPICS R3.14.9- $R3-14-9-pre1$ $2006/11/20 21:09:36$
## EPICS Base built Nov 20 2012
2012/12/12 11:08:38.678 asynManager::asynConnectCallback, port L0 error calling asynCommon! ->connect Can't connect to 192.168.0.21:1: Connection refused
2012/12/12 11:08:38.679 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.21:1: Connection refused
2012/12/12 11:08:38.680 Can't connect to 192.168.0.21:1: Connection refused L0 - 1 autoConnect could not connect
2012/12/12 11:08:38.681 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.21:1: Connection refused
2012/12/12 11:08:38.780 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.21:1: Connection refused
2012/12/12 11:08:38.781 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.21:1: Connection refused
2012/12/12 11:08:38.781 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.2 1:1: Connection refused
2012/12/12 11:08:38.784 asynManager:! :asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.21:1: Connection refused
2012/12/12 11:08:38.785 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.21:1: Connection refused
2012/12/12 11:08:38.786 asynManager::asynConnectCallback, port L0 error calling asynCommon->connect Can't connect to 192.168.0.21:1: Connection refused
iocInit: All initialization complete
## Start any sequence programs
#seq sncxxx,"user=felHost"
epics>
So, what probably has caused my problem?
Demin zhang
Re:RE: "Connection refused" when running Ethernet/RS232 application 张德敏
Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
Prev: Re: LeCroy DSO using VXI Nicholas P. DiMonte
Next: Re: Utilities for EPICS on Multi-Core Linux Shen, Guobao
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
Next: Re:RE: "Connection refused" when running Ethernet/RS232 application 张德敏
