Subject: Re:RE: "Connection refused" when running Ethernet/RS232 application
To: "Mark Rivers" <[email protected]>
Date: Thu, 13 Dec 2012 21:48:39 +0800 (CST)
When I use “telnet” from my Linux machine:
  telnet 192.168.0.21 1
I also get connection refused. But “ping 192.168.0.21”, it works well.
I can’t find the “TCP Server Mode” attribute of the port of the NI Ethernet/RS232 convertor(4 ports) , and the port likely needn’t to be configured.
Then, Is the port number the convertor’s port num or the device port in the machine? how should I set the port number in drvAsynIPPortConfigure?
RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Hu, Yong
Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
"Connection refused" when running Ethernet/RS232 application 张德敏
Prev: Re: .PACT .TIME Pavel Maslov
Next: RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Hu, Yong
Prev: RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
