1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Re:RE: "Connection refused" when running Ethernet/RS232 application
To: "'???'" <[email protected]>
Date: Thu, 13 Dec 2012 15:51:36 +0000
If telnet to that TCP port does not work then EPICS won’t work.  The fact that you can ping just means that the device exists.
Are you sure that port 1 is correct?  On the devices I have used the first serial port is typically TCP port 2001 or 4001.
Sent: Thursday, December 13, 2012 7:49 AM
To: Mark Rivers
Cc: 'Nicholas P. DiMonte'; tech-talk
Subject: Re:RE: "Connection refused" when running Ethernet/RS232 application
When I use telnet from my Linux machine:
  telnet 192.168.0.21 1
I also get connection refused. But ping 192.168.0.21, it works well.
I cant find the TCP Server Mode attribute of the port of the NI Ethernet/RS232 convertor(4 ports) , and the port likely neednt to be configured.
Then, Is the port number the convertors port num or the device port in the machine? how should I set the port number in drvAsynIPPortConfigure?
"Connection refused" when running Ethernet/RS232 application 张德敏
Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
Re:RE: "Connection refused" when running Ethernet/RS232 application 张德敏
Prev: EPICSPVFactory in CSS JavaScript Hovanes Egiyan
Next: RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
Next: EPICS SIMULINK interface Klotz Wolf-Dieter
