Subject: EPICSPVFactory in CSS JavaScript
Cc: Beni Zihlmann <[email protected]>
Date: Thu, 13 Dec 2012 10:15:07 -0500
we are trying to connect to EPICS variables from a CSS JavaScript script.
By looking at the CSS source and some examples we figured that we would need to use "EPICSPVFactory" class to create an object to connect to our EPICS variables.
This class is apparently defined in "org.csstudio.utility.pv.epics", so we
try the following short script:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
importPackage(Packages.java.lang);
importPackage(Packages.org.csstudio.utility.pv);
importPackage(Packages.org.csstudio.utility.pv.epics);
runnable = {
    run:function()
            var  pv = EPICSPVFactory.createPV( "epics://value1" );
new Thread(new Runnable(runnable)).start();
But when we run it, there is an error message:
Exception in thread "Thread-152" org.mozilla.javascript.EcmaError: ReferenceError: "EPICSPVFactory" is not defined. (script#11)
When we change "EPICSPVFactory.createPV" to "PVFactory.createPV", the error disappears. This is as if the "importPackage(Packages.org.csstudio.utility.pv.epics" statement has no effect. We are using SNS Basic EPICS CSS 3.1.2 product that we downloaded from the SNS web site. Is there something else or something different we need to do to be able to use the
"EPICSPVFactory" and "EPICS_V3_PV" classes in our scripts?
Thanks in advance,
     Hovanes.
RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
Prev: Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
Next: RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
Prev: calc R3-1 Tim Mooney
Next: RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
