Subject: Re: "Connection refused" when running Ethernet/RS232 application
To: 张德敏 <[email protected]>
Date: Thu, 13 Dec 2012 08:53:50 -0600
With a Moxa LAN-to-Serial, I can simply telnet into a port and control a serial device by typing the commands at the prompt.
After downloading the manual for the NI unit, I could find an mention using telnet.
Have you tried putting the IP# in a web browser, does it display a web page? any configuration info?
On 12/13/2012 7:48 AM, 张德敏 wrote:
When I use “telnet” from my Linux machine:
  telnet 192.168.0.21 1
I also get connection refused. But “ping 192.168.0.21”, it works well.
I can’t find the “TCP Server Mode” attribute of the port of the NI Ethernet/RS232 convertor(4 ports) , and the port likely needn’t to be configured.
Then, Is the port number the convertor’s port num or the device port in the machine? how should I set the port number in drvAsynIPPortConfigure?
Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
"Connection refused" when running Ethernet/RS232 application 张德敏
RE: "Connection refused" when running Ethernet/RS232 application Mark Rivers
Re:RE: "Connection refused" when running Ethernet/RS232 application 张德敏
Prev: RE: Re:RE: "Connection refused" when running Ethernet/RS232 application Hu, Yong
Next: Re: "Connection refused" when running Ethernet/RS232 application Nicholas P. DiMonte
