Subject: Re: EPICSPVFactory in CSS JavaScript
To: "Chen, Xihui" <[email protected]>
Cc: Beni Zihlmann <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 13 Dec 2012 12:05:27 -0500
Hello Xihui,
The scripts will be actually attached to a BOY widget. But the number of
EPICS variables used is going to be quite large, and they can change often as well,
so the scripts will be accessing different set of variables in different
conditions that can be determined within the script itself. I don't know
how to do these kind of things using input PVs of the widgets.
That is why we will try to use "Packages.org.csstudio.utility.pv" instead and see
in what kind of trouble we get.
Is there a way, hopefully a list, that can tell us which of the plugins that are included
in a CSS product can be imported from BOY javascripts? Our group is new to
CSS, and this would help us plan ahead regarding when we can use scripts for our
applications, and when we will have to develop new Eclipse plugins.
Thanks a lot for your help,
Hovanes.
On 12/13/2012 11:06 AM, Chen, Xihui wrote:
Hi Hovanes,
Packages.org.csstudio.utility.pv.epics is not exported from BOY, so you cannot use this package. In utility.pv, you should always use PVFactory to create PV. Also, it is not recommended to create PV in BOY script, because you need to manage the whole life cycle of the PV carefully, such as start() and stop(). Why don't you attach the PV to the script or a widget?
Xihui
Sent: Thursday, December 13, 2012 10:15 AM
To: [email protected]
Cc: Beni Zihlmann
Subject: EPICSPVFactory in CSS JavaScript
we are trying to connect to EPICS variables from a CSS JavaScript script.
By looking at the CSS source and some examples we figured that we would
need to use
"EPICSPVFactory" class to create an object to connect to our EPICS
variables.
This class is apparently defined in "org.csstudio.utility.pv.epics", so we
try the following short script:
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
importPackage(Packages.java.lang);
importPackage(Packages.org.csstudio.utility.pv);
importPackage(Packages.org.csstudio.utility.pv.epics);
runnable = {
      run:function()
              var  pv = EPICSPVFactory.createPV( "epics://value1" );
new Thread(new Runnable(runnable)).start();
But when we run it, there is an error message:
Exception in thread "Thread-152" org.mozilla.javascript.EcmaError: ReferenceError: "EPICSPVFactory" is not defined. (script#11)
When we change "EPICSPVFactory.createPV" to "PVFactory.createPV", the
error disappears.
This is as if the "importPackage(Packages.org.csstudio.utility.pv.epics"
statement has no effect.
We are using SNS Basic EPICS CSS 3.1.2 product that we downloaded from
the SNS web site.
Is there something else or something different we need to do to be able
to use the
"EPICSPVFactory" and "EPICS_V3_PV" classes in our scripts?
Thanks in advance,
       Hovanes.
RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
EPICSPVFactory in CSS JavaScript Hovanes Egiyan
Prev: RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
Next: Re: Utilities for EPICS on Multi-Core Linux Ralph Lange
Next: RE: EPICSPVFactory in CSS JavaScript Chen, Xihui
