Subject: Re: How to access menu choice strings inside record support
To: "Zhang, Dehong" <[email protected]>
Date: Thu, 13 Dec 2012 14:47:51 -0600
Have a look at
db/dbConvert.c: getMenuString()
this is a non-public routine but it's simple and you can extract
the relevant code/idea from there.
HTH
- Till
On 12/13/2012 02:12 PM, Zhang, Dehong wrote:
I am writing a custom record to deal with a particular hardware.  This
hardware has a few different operation modes, which are represented
with a set of name strings, not numbers.  We can talk to it to get or set this
mode, with strings.
The problem is, when a choice is made, we get a menu choice number.
Then I will need to find the corresponding name string, to write to the
hardware; on the other direction, when I query the hardware to find its
current mode, I get back a string.  Then I need to find the corresponding
choice number to set the button properly.
All these name strings are defined in the menu definition.  How can I
access them inside the record support?  Without having to declare
an array of strings, beside the menu definition?
Thanks much for your advices!  Best regards,
Dehong
How to access menu choice strings inside record support Zhang, Dehong
Prev: How to access menu choice strings inside record support Zhang, Dehong
Next: Re: How to access menu choice strings inside record support Andrew Johnson
