1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to access menu choice strings inside record support
To: [email protected]
Cc: "Zhang, Dehong" <[email protected]>
Date: Thu, 13 Dec 2012 15:05:40 -0600
Hi Dehong,
On 2012-12-13 Zhang, Dehong wrote:
> I am writing a custom record to deal with a particular hardware.  This
> hardware has a few different operation modes, which are represented
> with a set of name strings, not numbers.  We can talk to it to get or set
> this mode, with strings.
> The problem is, when a choice is made, we get a menu choice number.
> Then I will need to find the corresponding name string, to write to the
> hardware; on the other direction, when I query the hardware to find its
> current mode, I get back a string.  Then I need to find the corresponding
> choice number to set the button properly.
> All these name strings are defined in the menu definition.  How can I
> access them inside the record support?  Without having to declare
> an array of strings, beside the menu definition?
dbStaticLib.h defines the function
    dbMenu* dbFindMenu(DBBASE *pdbbase, const char *name);
The dbMenu structure is defined in dbBase.h which gets included by
dbStaticLib.h anyway.
So to access the choice strings you could use a function like this:
const char * menuChoice(const char *menuName, epicsEnum16 index)
    dbMenu pMenu = dbFindMenu(pdbbase, menuName);
    if (!pMenu || index >= pMenu->nChoice)
        return NULL;
    return pMenu->papChoiceName[index];
Note that dbFindMenu() uses a hash table which is reasonably fast, but you
might still want to do the lookup just once at initialization and save the
dbMenu pointers for all your menus.
The disadvantage of making your menu choices identical to the strings that you
use to communicate with the device is that you can't change their wording to
make them easier for your users to understand.  I would think carefully about
that before using the above code, although there's nothing inherently wrong
with using this approach if that's acceptable.
HTH,
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
How to access menu choice strings inside record support Zhang, Dehong
Prev: Re: How to access menu choice strings inside record support Till Straumann
Next: EPICS 3.14.12.2 on VirtualBox Jiro Fujita
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
