Subject: Re: s7nodave
To: EPICS Tech Talk <[email protected]>
Date: Wed, 19 Dec 2012 19:57:16 +0300
Just to let you know, I have successfully connected EPICS to the S7-300 PLC (CPU317-2 PN/DP) using the latest version of s7nodave (http://oss.aquenos.com/epics/s7nodave/download/s7nodave-1.0.1.tar.gz).
The connection is established via a built-in Profinet port. Don't know how it works on the CP module, though. But am planning to check it out!
For those who have used s7nodave, do you see any pros in comparison with s7plc?
As I can see s7nodave establishes connection to port 102 (ISO-over-TCP). Whereas, s7plc can have a number of connections simultaneously (on different TCP ports). Or am I missing something?
On Sun, Dec 9, 2012 at 9:04 PM, Pavel Maslov <[email protected]> wrote:
Hello there,
Has anyone used s7nodave (http://oss.aquenos.com/epics/s7nodave/) to talk to the Siemens S7 300/400 PLC over Ethernet?
Does it work with both CP and built-in Ethernet port?
Looks like cool stuff.
From what I can see in the manual it's a little bit more convenient than the s7plc module from SLS. Because one can directly read/write from/to the PLC data blocks.
But what are your thoughts?
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Best regards,
Pavel Maslov, MS
s7nodave Pavel Maslov
Prev: Re: How to get a list of all available PVs Eric Norum
Next: Re: How to get a list of all available PVs Pavel Maslov
Prev: s7nodave Pavel Maslov
Next: Alcatel ACT 600T and 600TH turbo pumps Pierrick Hanlet
