Subject: devlib2 bugfix (rare string corruption)
To: "Davidsaver, Michael" <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 19 Dec 2012 11:59:53 -0600
vallocPrintf()
first calls vsnprintf() with a length argument of zero to determine
the necessary buffer size, allocates a buffer and then calls
size2 = vsprintf(buf,format,args)
It then goes on and complains if size2 is different from what the
initial vsnprintf() returned.
If, however, this really happens (and I have observed this under 64-bit ubuntu-12.10) then it is well possible that vsprintf() writes beyond the length of the buffer.
Hence, I suggest to replace vsprintf() by
size2 = vsnprintf(buf, size+1, format, args)
just to make sure. (Note that the 'size' argument to snprintf() includes space for
the terminating NUL whereas the return value does not.)
- Till
A patch is attached for sake of convenience.
diff -r ed471db5e741 pciApp/os/Linux/devLibPCIOSD.c
--- a/pciApp/os/Linux/devLibPCIOSD.c	Wed Dec 19 11:52:40 2012 -0600
+++ b/pciApp/os/Linux/devLibPCIOSD.c	Wed Dec 19 11:53:34 2012 -0600
@@ -187,7 +187,7 @@
         errlogPrintf("vaprintf: Failed to allocate memory for format '%s'\n",format);
         goto fail;
-    size2=vsprintf(ret,format,args);
+    size2=vsnprintf(ret,size+1,format,args);
     if (size!=size2) {
         errlogPrintf("vaprintf: Format yielded different size %d %d : %s\n",size,size2,format);
         goto fail;
Re: devlib2 bugfix (rare string corruption) Michael Davidsaver
Prev: [makefile] adding a library to an EPICS application Pavel Maslov
Next: Re: [makefile] adding a library to an EPICS application Martin Konrad
Prev: Re: [makefile] adding a library to an EPICS application Ralph Lange
Next: Re: devlib2 bugfix (rare string corruption) Michael Davidsaver
