Subject: Re: [makefile] adding a library to an EPICS application
To: [email protected]
Date: Wed, 19 Dec 2012 17:38:35 -0600
On 2012-12-19 Mark Rivers wrote:
> What I can't answer, but hopefully Janet Anderson can, is how you tell
> EPICS to look for a library in a location other than the standard Linux
> search path for include files and libraries.
You tell the build system where to find libXxx.a or libXxx.so by setting the
variable Xxx_DIR to the directory containing the library.  In Pavel's case his
Makefile has the line
    hello_LIBS += my_library
so he needs
    my_library_DIR = /where/my/library/lives
For include file directories, the simplest way is to set USR_INCLUDES like
this:
    USR_INCLUDES += -I /where/my/headers/live
You can also set OS-specific paths if you need to, for example
    USR_INCLUDES_Linux += -I /my/linux/headers
In general I recommend making use of the EPICS build system if you can because
we take care of things like creating dependency files and handling multiple
architecture builds from the same source tree; most other build systems need
you to do extra work for that kind of thing.
HTH,
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
Re: [makefile] adding a library to an EPICS application Martin Konrad
[makefile] adding a library to an EPICS application Pavel Maslov
RE: [makefile] adding a library to an EPICS application Mark Rivers
Prev: Re: cross-compile error S. Banerian
Next: SNL with C Pierrick M Hanlet
Prev: RE: [makefile] adding a library to an EPICS application Mark Rivers
Next: Re: [makefile] adding a library to an EPICS application Martin Konrad
