Subject: Re: [makefile] adding a library to an EPICS application
To: EPICS Tech Talk <[email protected]>
Date: Thu, 20 Dec 2012 11:00:30 +0100
On 20.12.2012 10:37, Pavel Maslov wrote:
Thanks everyone!
And particularly, MArk and Andrew! Your insights have helped a lot!
Let me ask you one more question. Perhaps, Andrew will give a rightaway answer. What makefile command (in $(TOP)/xxxApp/Db/Makefile) can I use to copy an arbitrary file (in my case $(TOP)/xxxApp/Db/TDS.proto) to $(TOP)/db.
DB_INSTALLS += TDS.proto doesn't work.
Any other thoughts?
According to the Application Developer's Guide (section 4.7), you need to specify the full path, i.e.
DB_INSTALLS += $(TOP)/xxxApp/Db/TDS.proto
Did you try that?
~Ralph
Re: [makefile] adding a library to an EPICS application Pavel Maslov
RE: [makefile] adding a library to an EPICS application Mark Rivers
Re: [makefile] adding a library to an EPICS application Andrew Johnson
Re: [makefile] adding a library to an EPICS application Martin Konrad
Prev: Re: [makefile] adding a library to an EPICS application Pavel Maslov
Next: Re: [makefile] adding a library to an EPICS application Pavel Maslov
