Subject: RE: structs and SNL
To: "'Pierrick Hanlet'" <[email protected]>
Date: Thu, 20 Dec 2012 21:51:14 +0000
> Does your response mean that I can then simply extract the value
> of myVar from which was filled in my function and called from
> the SNL code by:  PV->myVar?  If so, I still have a problem.
The fact that the name myVar is the same in the SNL and the struct is not relevant, they are different things.
Your C code would need to copy the value from the struct to the float myVar.
    pVar->myVar = PV.myVar;
If you want to look at an example which uses escaped C functions and the pVar pointer look at
motor/motorApp/NewportSrc/XPS_trajectoryScan.st in the synApps "motor" module:
http://www.aps.anl.gov/bcda/synApps/motor/
Cheers,
Sent: Thursday, December 20, 2012 3:29 PM
To: Mark Rivers
Cc: 'Zelazny, Michael Stanley'; [email protected]
Subject: Re: structs and SNL
Hi all,
Thanks for the help.  I'm still confused, however.
I have the struct defined in a header file which I do have escaped:
%%#include "MICEStates.h"
The name of the struct is PV.
I then define the same variables in my SNL code
float myVar   (also in the struct).
I have a C function which uses the same header file and and fills the
variables in the struct.  This code I successfully build into the SNL
code.
The documentation states:
The sequencer allocates the structure area at run time and passes a pointer
to this structure into the program.  The structure has the following type:
struct UserVar *pVar;
Sorry if I'm slow on understanding.
Pierrick
On 12/20/2012 02:14 PM, Mark Rivers wrote:
You must escape declarations of variables with types like struct, they are not known types to SNL.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Zelazny, Michael Stanley
Sent: Thursday, December 20, 2012 11:22 AM
To: Pierrick Hanlet
Cc: [email protected]
If you "escape to C" the .h with "%%" then you'll have to do the same with your struct declaration.
cc-ing tech-talk for further comments from others.
Sent: Thursday, December 20, 2012 6:07 AM
To: Zelazny, Michael Stanley
Subject: structs and SNL
Hi Michael,
I think that I understand reentrant to mean (in part) that variables in SNL and C-code
can be related.  Assuming that is true, then I'm attempting to implement the section
"Variable Modification for Reentrant Option".  My C code reads our database and I
would like to use some of the variables from there in an entry block of a particular
state.
So, in the top-level declarations I define a number a variables which have the same
declaration as those in a struct in a header which I include in the top-level with %%
escape:
option +r;
char name[50];
If I understand the documentation, I should be able to do:
struct PV *cPV;
where PV is the name of my struct in the header file (I also tried UserVar, as
in the example).  However, at compile time, I get the error "type specifier".
This error follows the "struct" statement wherever I put it in the code.
Can you tell me what I'm doing incorrectly?
Thank you.
Pierrick--
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Pierrick Hanlet
IIT/Fermilab
SNL with C Pierrick M Hanlet
RE: SNL with C Zelazny, Michael Stanley
Re: SNL with C Pierrick Hanlet
RE: structs and SNL Zelazny, Michael Stanley
RE: structs and SNL Mark Rivers
Re: structs and SNL Pierrick Hanlet
Prev: Re: structs and SNL Pierrick Hanlet
Next: CSS XY Graph Pause John Dobbins
Next: RE: SNL with C Mark Rivers
