Hi John, Is there an option "Plot n points and stop" in CSS Boy? Another solution would be to implement a record that will use the SDIS field of your waveform record to switch it back and forth (1 to 0). So you will click the button and it stops updating data from the scope. Click again, and - presto! - new data has arrived.
On Fri, Dec 21, 2012 at 2:28 AM, John Dobbins <[email protected]> wrote: Hello All, Best regards, Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus St. Petersburg, Russia Mobile: +7 (951) 672 22 19 Landline: +7 (812) 461 01 01
| ANJ, 18 Nov 2013 |
Home
News
About
Talk
Base
Modules
Extensions
