Hi John
We do this by adding a pause button with a javascript action to disable
the waveforms. It works, but the graph widget "pinks out", that's a
feature of course. Pavel's idea to disable at the IOC may be better, but
it does mean that all scope displays freeze, while the local disable is
just that, local.
Cheers
Peter
example javascript (8 traces on display):
importPackage(Packages.org.csstudio.opibuilder.scriptUtil);
var pause = display.getVar("pause");
var xygraph=display.getWidget("XY Graph");
if(pause == null || pause==false){
display.setVar("pause", true);
for (var tr = 0; tr < 8; ++tr){
var key = "trace_"+tr+"_y_pv";
display.setVar(key, xygraph.getPropertyValue(key));
xygraph.getPV(key).stop();
widget.setPropertyValue("text", "Resume");
}else{
display.setVar("pause", false);
xygraph.setPropertyValue(key, display.getVar(key));
xygraph.getPV(key).start();
widget.setPropertyValue("text", "Pause");
On 12/21/2012 07:41 AM, Pavel Maslov wrote:
Hi John,
Is there an option "Plot n points and stop" in CSS Boy?
Another solution would be to implement a record that will use the SDIS
field of your waveform record to switch it back and forth (1 to 0). So
you will click the button and it stops updating data from the scope.
Click again, and - presto! - new data has arrived.
On Fri, Dec 21, 2012 at 2:28 AM, John Dobbins <[email protected]
<mailto:[email protected]>> wrote:
Hello All,
I am using a CSS XY graph to display a waveform. The graph actually
displays the last n values on the waveform presenting an
oscilloscope like trace. I would like to be able to pause the
display. Can someone recommend a way of doing this?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
Peter Milne [email protected]
D-TACQ Solutions Ltd www.d-tacq.com
- CSS XY Graph Pause John Dobbins
- Re: CSS XY Graph Pause Pavel Maslov
Re: CSS XY Graph Pause Rod Nussbaumer
<2012>
2025
2026
<2012>
2025
2026
