Hi John.
I have some applications that use StreamDevice to acquire waveforms, and
those waveform records are normally on a periodic scan. I have a couple
of records which provide the display manager (EDM, here) with a choice
button for the scan rate, one choice of which is 'Pause'. This sets the
waveform record to scan 'passive', thus stopping the acquisition. You
can attach a choice button directly to the .SCAN field of the record
that triggers an acquisition, but there will be some values that
operators probably don't want to see or select. This may differ from
what you really want, as the entire acquisition stops in this scenario,
not just the display. You might be able to use a system of records that
duplicates the waveform; one for continuous processing, and another for
visualization only.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada.
On 12/20/2012 02:28 PM, John Dobbins wrote:
Hello All,
I am using a CSS XY graph to display a waveform. The graph actually
displays the last n values on the waveform presenting an oscilloscope
like trace. I would like to be able to pause the display. Can someone
recommend a way of doing this?
John Dobbins
Lab for Elementary Particle Physics
Cornell University
- CSS XY Graph Pause John Dobbins
Re: CSS XY Graph Pause Peter Milne
APS Network Service Disruptions Andrew Johnson
<2012>
2025
2026
<2012>
2025
2026
