1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: unable to see epics variables
To: Pavel Maslov <[email protected]>
Date: Thu, 3 Jan 2013 14:52:18 -0500
Hello,
Thanks for the response.  Good thinking too.  It is one of our machines that has a firewall blocking outgoing signals.  As a temporary solution I'm allowing all computers that need to access the affected epics channels through the firewall.  Hopefully I'll be able to figure out a more elegant solution as well.
Thanks!
James
On Thu, Jan 3, 2013 at 1:47 PM, Pavel Maslov <[email protected]> wrote:
Maybe iptables -F will help?
On Thu, Jan 3, 2013 at 10:31 PM, Mark Rivers <[email protected]> wrote:
caget uses ports 5064 and 5065 by default.  It uses UDP to locate which IOC has the PV, and then TCP to read the value.
The fact that you can ping makes it sound like there is a firewall somewhere blocking ports 5064 or 5065.  Those both need to be open for both UDP and TCP.
From: [email protected] [mailto:[email protected]] On Behalf Of James F Ross
Sent: Thursday, December 27, 2012 12:51 PM
To: EPICS Tech Talk
Subject: unable to see epics variables
Hello everyone,
I am not sure if this is an epics problem or not, but if anyone has any insight I would appreciate the help.  The error is the following:
$> caget fgt:status
CAC: Unable to connect because "No route to host"
CA.Client.Exception...............................................
    Warning: "Virtual circuit disconnect"
    Context: "softioc3.starp.bnl.gov:52008"
    Source File: ../cac.cpp line 1214
    Current Time: Thu Dec 27 2012 13:44:42.760798000
cagChannel connect timed out: 'fgt:status' not found.
I have been unable to find anything blocking a route to the host, and I can ping the host from the machine I am trying the caget on. Historically this has been caused by firewall issues, but even with all security (iptables and selinux) disabled I still get this problem.  Is there anything epics related that can cause this issue?  Something that isn't running but should be in order to allow the command caget to connect?
It would be helpful to know exactly how caget looks over a network.  Is there a particular port it uses?  Does it look via rsh or NFS or some other connection type that may not be working for some reason?
Three machines spontaneously started having this issue which points to it being a network problem and thus nothing tech talk can help me with, but the fact that I can ping each host from the three machines having problems indicates that there is in fact a network connection and may be epics related.
Thanks for the help,
James Ross
Best regards,
Pavel Maslov, MS
Controls Engineer at Pulsed power Lab
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Landline: +7 (812) 461 01 01
unable to see epics variables James F Ross
RE: unable to see epics variables Mark Rivers
Re: unable to see epics variables Pavel Maslov
Prev: areaDetector application for Basler Camera 郭策
Next: RE: areaDetector application for Basler Camera Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: unable to see epics variables Pavel Maslov
Next: RE: Error in installing asyn driver Mark Rivers
