Hi Jack,
On 2013-01-07 Jack Smith wrote:
> As Ralph said below, rsrv is the old C Channel Access server. I
> suppose cas is the new C++ Channel Access server. Here are my
> questions:
> 1. Why do we need both rsrv and cas? What functionalities are provided
> in each module?
RSRV is still used by the IOC database. The APIs to the two servers are
different. RSRV is written in C and knows how to talk to the database, CAS is
written in C++ and has a more general interface, but its data interface turned
out to *not* be appropriate to use in the IOC, which is why it has never
replaced RSRV in that role. There has been a 10+ year long project to write a
better data interface and modify CAS to make use of it, but it's looking like
it may be hard to merge that at this point.
> 2. When I use makeBaseApp to create an example IOC application, there
> is one line "example_LIBS += $(EPICS_BASE_IOC_LIBS)" in the app's
> src/Makefile and there is an output message "-lrecIoc -lsoftDevIoc
> -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc
> -ldbStaticIoc -lca -lCom" during the app building. I see "rsrvIoc"
> and "ca" are included in the IOC. I suppose the "ca" is the Channel
> Access Client library because an IOC could be Channel Access Server as
> well as Channel Access Client. But I don't see something like 'cas' in
> the linked EPICS base libraries. Where is 'cas' included, dbIoc or
> dbStaticIoc or some else?
CAS is not used by IOCs. If you use makeBaseApp to create an application with
type caServer you'll get a sample server application which shows you the
interface to CAS. CAS is used by the PV Gateway, the CA Nameserver, and
various other server interfaces to other control systems.
HTH,
- Andrew
There is no such thing as a free lunch. When invited for lunch,
it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
- RE: rsrv and cas Hill, Jeff
- RE: rsrv and cas Hu, Yong
- rsrv and cas Jack Smith
Qt workshop presentations Paul Sichta
<2013>
2025
2026
<2013>
2025
2026
