1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: rsrv and cas
To: "'Andrew Johnson'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 7 Jan 2013 23:00:47 +0000
cas is also named Portable Channel Access Server (PCAS) or Channel Access Portable Server, see http://www.aps.anl.gov/epics/extensions/cas/index.php . CAS is on the list of EPICS Extensions, but it's actually part of the Base.
Yong
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Monday, January 07, 2013 3:05 PM
To: [email protected]
Subject: Re: rsrv and cas
Hi Jack,
On 2013-01-07 Jack Smith wrote:
> As Ralph said below, rsrv is the old C Channel Access server. I
> suppose cas is the new C++ Channel Access server. Here are my
> questions:
> 1. Why do we need both rsrv and cas? What functionalities are provided
> in each module?
RSRV is still used by the IOC database.  The APIs to the two servers are different.  RSRV is written in C and knows how to talk to the database, CAS is written in C++ and has a more general interface, but its data interface turned out to *not* be appropriate to use in the IOC, which is why it has never replaced RSRV in that role.  There has been a 10+ year long project to write a better data interface and modify CAS to make use of it, but it's looking like it may be hard to merge that at this point.
> 2. When I use makeBaseApp to create an example IOC application, there
> is one line "example_LIBS += $(EPICS_BASE_IOC_LIBS)" in the app's
> src/Makefile and there is an output message "-lrecIoc -lsoftDevIoc
> -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc
> -ldbStaticIoc -lca -lCom"  during the app building. I see "rsrvIoc"
> and "ca" are included in the IOC. I suppose the "ca" is the Channel
> Access Client library because an IOC could be Channel Access Server as
> well as Channel Access Client. But I don't see something like 'cas' in
> the linked EPICS base libraries. Where is 'cas' included, dbIoc or
> dbStaticIoc or some else?
CAS is not used by IOCs.  If you use makeBaseApp to create an application with type caServer you'll get a sample server application which shows you the interface to CAS.  CAS is used by the PV Gateway, the CA Nameserver, and various other server interfaces to other control systems.
HTH,
- Andrew
There is no such thing as a free lunch.  When invited for lunch, it is best to check if you are there to eat, or to be eaten.
-- Clive Robinson
rsrv and cas Jack Smith
Re: rsrv and cas Andrew Johnson
Prev: RE: rsrv and cas Hill, Jeff
Next: motor cable assembly questions Pete Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Qt workshop presentations Paul Sichta
