1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: motor cable assembly questions
To: EPICS Tech Talk <[email protected]>
Date: Mon, 07 Jan 2013 17:57:24 -0600
As a result of a recent electrical shock incident at the APS, we are
interested in learning which standards for stepping motor connectors
and cable assemblies are in use at other facilities.  Our focus is on
motor cable assemblies for use with stepping motor drivers which
operate above 50 VDC.
Our interest stems from a recent incident in which an intermittent
short-circuit was created inside the connector shell of a standard
APS motor cable.  The short was between a motor phase current
conductor and the metal shell of the connector.  We are considering
developing a new standard cable assembly for motor drivers that
We would be pleased if the EPICS community could help us by answering these questions:
* How does your facility standardize motor cables
  and connectors?
* How does your standard distinguish between
  systems with drivers that only operate below 50 VDC
  from systems with drivers that may operate above 50 VDC?
* How does your facility handle grounding of the connector?
* Are limit, home, and encoder signal conductors in a separate cable?
* How does your facility test motor cable assemblies?
* Do you test motor cable assemblies for insulation breakdowns?  How?
* Is there a standard to switch off the motor driver
  if the end-of-travel limit switches have been passed?
* Do you have other comments?
   Pete
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
RE: motor cable assembly questions tom.cobb
Prev: RE: rsrv and cas Hu, Yong
Next: RE: Qt workshop presentations Andrew Rhyder
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Qt workshop presentations Andrew Rhyder
Next: RE: motor cable assembly questions tom.cobb
