1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: What's calling get_array_info?
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Wed, 09 Jan 2013 14:22:18 -0500
Hi Tim,
On 1/9/2013 12:48 PM, Tim Mooney wrote:
Overwriting pfield does cause problems.  When you post the array, you have to post all three pfield addresses, because you can't know which was in use at the time a client connected.  (As you know, clients actually connect to array addresses, not to fields.) There are three pfield addresses, because buffers are not allocated until a detector field is first used, so the first address is the null array, and the other two are the actual data buffers.  The posting only alerts clients that new data is available; the real buffer address isn't specified until the client calls get_array_info().  It's awkward and unsatisfying, but it works.
Tim
Ok, so there are issues, but not as bad as they could be.
One of the things I am considering is to modify the code which calls get_array_info() to be aware that paddr->pfield might be modified, and clean up afterward.  Would this adversely effect sscanRecord?
DBADDR *paddr;
  void *temp = paddr->pfield;
  ...->get_array_info(paddr, ...);
  dbGet(paddr, ...);
  paddr->pfield = temp;
I had also considered adding another argument to get_array_info(), or another member to DBADDR.  However, as there is already code modifying DBADDR, that seems like the way to go.
Michael
To: "Ned Arnold" <[email protected]>
Sent: Wednesday, January 9, 2013 11:02:49 AM
On 1/9/2013 11:57 AM, Ned Arnold wrote:
The sscan record in synapps does that ... if you are looking for an example.  It "double buffers" the collected data allowing a client more time to access it.
From sscanRecord.c:
if (precPvt->validBuf == B_BUFFER) {
      paddr->pfield = precPvt->detBufPtr[group].pBufB;
} else {
      paddr->pfield = precPvt->detBufPtr[group].pBufA;
Well how about that.  This is just what I was thinking.  I had assumed that simply overwriting pfield would cause problems.  I'll definitely take a close look at this code.
Michael
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Re: What's calling get_array_info? Tim Mooney
Prev: Re: time drift in camonitor timestamps Eric Norum
Next: Re: time drift in camonitor timestamps Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: What's calling get_array_info? Tim Mooney
Next: medm build D Peter Siddons
