1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Alter Perl hashbang in capr.pl
To: EPICS Tech Talk <[email protected]>
Date: Fri, 18 Jan 2013 15:14:32 -0600
On 1/18/13 2:58 PM, Ralph Lange wrote:
> Hi Murali,
> one way to get around this (this is what the EPICS build system does)
> would be not to use the hashbang by explicitly calling perl with the
> script as argument:
>     perl ./bin/linux-x86_64-debug/capr.pl
> Admittedly, this avoids the issue and does not fix it.
> A more elegant portable solution is replacing the hashbang with
>     eval 'exec perl -S $0 ${1+"$@"}' # -*- Mode: perl -*-
>         if 0;
> That will find perl in the PATH.
??  I would say the correct thing to do would be for the hashbang in
capr.pl (and all others) to be set correctly based on the PERL variable
from the EPICS build system at build time.
Lewis
Alter Perl hashbang in capr.pl Shankar, Murali
Re: Alter Perl hashbang in capr.pl Ralph Lange
Prev: Re: Alter Perl hashbang in capr.pl Ralph Lange
Next: Re: Alter Perl hashbang in capr.pl Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
