Hi Tim,
Thanks for your help. I've gotten much further, but was unable to
complete the build of the
test facility withing seq. However, I was successful in building
std without it. I was traveling
yesterday when I received your response, so I'm only now getting
back to this.
Now, I'm back to my ioc. As previously written, I've successfully
built all of this code on
another machine. When I do a line-by-line comparison of the
execution of the Makefile
on the successful build vs new build, I find that my new build fails
at the point that the
successful build prints "converting ../sncMICEStates.stt"
(immediately after expanding
the dbd file). My new build gives the line:
make[3]: *** No rule to make target sncMICEStates.o', needed by
libMICEStatesSupport.a'. Stop
Pierrick
On 01/20/2013 10:45 AM, Tim Mooney wrote:
Hi Pierrick,
First, make sure that std/configure/RELEASE has a line like the following:
SNCSEQ=$(SUPPORT)/seq
or
SNCSEQ=home/controls/support/seq
Then, replace seq/configure/RULES_BUILD with the following:
ifdef SNCSEQ
SNC = $(SNCSEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
ifdef SEQ
SNC = $(SEQ)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
else
SNC = $(INSTALL_LOCATION)/bin/$(EPICS_HOST_ARCH)/snc$(HOSTEXE)
endif
endif
Then, do a "make rebuild" in seq and std.
Tim
----- Original Message -----
To: "Tech Talk" <[email protected]>
Sent: Sunday, January 20, 2013 9:37:16 AM
Subject: femto and std
I followed the thread on techtalk but did not find a solution to the
problem regarding building std.
I don't have a 64 bit machine. I'm using 3.14.11 and std-3.1 or
std-2.8
and seq-2.1.11. This does
build on a couple of other machines I'm using.
/usr/bin/gcc -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500 -D_X86_ -DUNIX -D_BSD_SOURCE -Dlinux
-D_REENTRANT -O3 -Wall -m32 -g -fPIC -I. -I../O.Common
-I.
-I.. -I../../../include/os/Linux -I../../../include
-I/home/controls/support/seq/include
-I/home/controls/support/asyn4-19/include
-I/home/epics/base-3-14-11/include/os/Linux
-I/home/epics/base-3-14-11/include ../pvHistory.c
make[3]: *** No rule to make target `femto.o', needed by `libstd.a'.
Stop.
Pierrick
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
*Pierrick Hanlet*
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
Pierrick Hanlet
IIT/Fermilab
- Re: femto and std Tim Mooney
DXP ElapsedRealTime Hinko Kocevar
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
