I'm trying to understand an IOC that generates a controls monitoring webpage at STAR. For whatever reason, the IOC is not writing the html file that it should be (it has worked in the past). The source code is a number of .stt files, each of which handles variables for a different subsystem. Ultimately all of these variables are brought together using a file called overall.stt, and the webpage is written by a file called overallhtml.stt. When the IOC is compiled, these .stt files produce .c files of the same name. What I'm wondering is, how are these c files used? Do they become binary files when the IOC is compiled? What generally happens in an IOC between these c files and a sequencer program being called in the start up script for the IOC? The sequencer programs are loaded as follows in the IOC startup file: seq mot_gas seq trig seq eemc seq bemc seq tofm seq overall seq overallhtml Are these binary executable files that are being called, or does the startup script read the c code directly? I can't find any binary files by these names on the computer, but I see no errors while compiling either. If anyone has any insight I could use a hand. I know you won't know specifics on my setup, but any help with sequencer programs in general would be nice. Thanks very much! James Ross
| ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
