1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: DXP ElapsedRealTime
To: "'Hinko Kocevar'" <[email protected]>, Tech Talk <[email protected]>
Date: Tue, 22 Jan 2013 14:48:08 +0000
Hi Hinko,
> I was expecting that $(P)ElapsedRealTime would hold some other time
> value - maybe cumulative for all MCA channels..
That PV holds the maximum elapsed real time for any channel.  The calculation is done at line 2821 in NDDxp.cpp:
           getDoubleParam(i, mcaElapsedRealTime, &realTime);
           realTime = MAX(realTime, dvalue);
> Also since the 16element_dxp.adl looks like a "top" level panel, for
> controling 16 detector channels, why would we need to make a separate
> instance of it (according to dxpDoc.html) for each detector channel?
It is a top-level panel and you don't need to make a separate instance of it for each detector channel.  I searched dxpDoc.html for the string 16element_dxp.adl and I don't see any mention of making separate instances of it.  Can you please send me the text that you are referring to?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Hinko Kocevar
Sent: Tuesday, January 22, 2013 7:20 AM
To: Tech Talk
Subject: DXP ElapsedRealTime
I'm trying to understand how the counting of Elapsed Real Time is done
in the $(P)ElapsedRealTime record found in dxpHighLevel.template and
seen on 16element_dxp.adl panel.
I can understand that each MCA record (seen in the mca_simple.adl)
counts its own Elapsed real time in the .ERTM field.
Best regards,
Hinko Kocevar
Re: DXP ElapsedRealTime Hinko Kocevar
Prev: DXP ElapsedRealTime Hinko Kocevar
Next: sequencer programs in an IOC James F Ross
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: DXP ElapsedRealTime Hinko Kocevar
