1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: DXP ElapsedRealTime
To: Tech Talk <[email protected]>
Date: Wed, 23 Jan 2013 13:13:21 +0100
Hi Mark,
On 01/22/2013 03:48 PM, Mark Rivers wrote:
Hi Hinko,
I was expecting that $(P)ElapsedRealTime would hold some other time
value - maybe cumulative for all MCA channels..
That PV holds the maximum elapsed real time for any channel.  The calculation is done at line 2821 in NDDxp.cpp:
            getDoubleParam(i, mcaElapsedRealTime, &realTime);
            realTime = MAX(realTime, dvalue);
Line 2821 in NDDxp.cpp is more or less EOF in the code I'm looking at - dxpR3-1. But on line 1814 and 1815 I can find the lines you are referring too. Thanks!
Correct me if I'm wrong, the DXP system can be composed of different number of channels (1 - 16 or even more). So the $(P)ElapsedRealTime shows the maximum Real time as seen by any of the active channels belonging to the DXP system.
Also since the 16element_dxp.adl looks like a "top" level panel, for
controling 16 detector channels, why would we need to make a separate
instance of it (according to dxpDoc.html) for each detector channel?
It is a top-level panel and you don't need to make a separate instance of it for each detector channel.  I searched dxpDoc.html for the string 16element_dxp.adl and I don't see any mention of making separate instances of it.  Can you please send me the text that you are referring to?
I was reading this on some printed sheets I have - but I do not have them at hand. The statement is more a deduction from compiling several information from the code, DB and docs I have, rather than a direct statement in the docs.
The implication was that dxpHighLevel.template defines the $(P)ElapsedRealTime the 16element_dxp.adl is showing it. Since 16element_dxp.adl is obviously top level panel, I was surprised to see it was showing a PV from the template that is instantiated multiple times (dxpHighLevel.template). That is why the statement "according to dxpDoc.html" was made, because it indeed does say, in the dxpHighLevel.template section:
".. One instance of this database is loaded for each detector channel in the system. .."
Looking at the online versions of panels, templates and docs again, I can't find the use of $(P)ElapsedRealTime in any ADL panel - only $(P)ElapsedReal is used. I need to verify this info with my printed docs later on this week.
Hinko
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Hinko Kocevar
Sent: Tuesday, January 22, 2013 7:20 AM
To: Tech Talk
Subject: DXP ElapsedRealTime
I'm trying to understand how the counting of Elapsed Real Time is done
in the $(P)ElapsedRealTime record found in dxpHighLevel.template and
seen on 16element_dxp.adl panel.
I can understand that each MCA record (seen in the mca_simple.adl)
counts its own Elapsed real time in the .ERTM field.
Best regards,
Hinko Kocevar
RE: DXP ElapsedRealTime Mark Rivers
DXP ElapsedRealTime Hinko Kocevar
Prev: Re: Edm installation Mauro Giacchini
Next: RE: DXP ElapsedRealTime Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: DXP ElapsedRealTime Mark Rivers
